Old 01-13-2014, 11:33 AM   #1
racer32
Default Weird engine number: RF4504
Maybe it's just newbie ignorance here, but I just brought home this engine that was in a friend of mine's AA truck. What's up with the serial number? Shouldn't it be AA-something? It doesn't look as though the pad has been machined.
racer32 is offline   Reply With Quote
Old 01-13-2014, 11:51 AM   #2
MALAK
MALAK's Avatar
Default Re: Weird engine number: RF4504
It was probably a replacement engine and may have come out of some industrial or farm equipment. It may be a ♦ (diamond) block. Ford sold Model A engines for industrial use (without Ford SN's) where the manufacturer of the equipment may or may not have stamped their own SN. Attached is a pic of a Diamond Block I have with a clearly unmolested SN, like yours.
MALAK is offline   Reply With Quote
Old 01-13-2014, 11:51 AM   #3
johnbuckley
johnbuckley's Avatar
Nothing to fret about -I bet it has been machined sometime- can you post a picture- the script may give a clue.Many As carry peculiar engine numbers- often the original number was ground down prior to restamping with with whatever Old George felt like when it was rebuilt sometime in the last eighty years.
Old 01-13-2014, 12:59 PM   #4
J Franklin
J Franklin's Avatar
Big Daddy Roth!
Old 01-13-2014, 01:00 PM   #5
racer32
Forgot to mention...it does have the star stamps before and after the number.
Old 01-13-2014, 01:10 PM   #6
racer32
Hunting USB cable for wife's camera. Will post a pic when I find it.
Old 01-13-2014, 01:16 PM   #7
Bob C
I think it stands for Richmond Ford, see the link.
http://www.fordbarn.com/forum/showthread.php?t=38520
Bob
Old 01-13-2014, 01:17 PM   #8
C4engr
C4engr's Avatar
My 31 engine has RF7428.... I was told 40 + years ago that the R indicates the engine was built at the Richmond CA engine plant..
Rog
C4engr is offline   Reply With Quote
Old 01-13-2014, 01:31 PM   #9
racer32
Bob
Just looked at the link. There is a small diamond on the block above the timing cover. 12E6 casing date. So now that the mystery is solved...do I have anything good? Engine is supposed to run, but the head has a long crack in the top.
Old 01-13-2014, 03:50 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Since the head has a freeze crack (darn water) I would also check the block for cracks in the cooling chambers. Also be sure to clean out the coolant chamber while the head is off. Using water only causes rust and there might be a lot of rust flakes hiding in the rear of the block, as there were in my used engine.
Old 01-14-2014, 07:06 PM   #11
racer32
Tom, I'll definitely check it if/when I get around to pulling it apart. I'm hoping it's OK, but the freeze damage to the head concerns me. Since the head's toast, is there much hope for a crack-free block?
Old 01-14-2014, 07:52 PM   #12
Joe K
Joe K's Avatar
Quite a lot of hope, actually. The usual tendency of these things was to fail the centerline of the head longitudinally. This provided "relief space" and prevented damage to lower parts of the cooling shroud.
You can check it with the head off. Drain coolant. Remove head. Then fill gently (including radiator if you're sure of it) up to the open spaces around the cylinders using an eyedropper towards the end (overstated but you get the idea.)
If the coolant won't stay at the level, then you have a leak somewhere. You may see it on the floor. Or possibly in the oil pan (don't forget the water jacket is two sided.) Best indication is dropping level which you can easily see.
Good luck with this. Even heads can be welded shut - but it's hardly worth the effort. $25 will usually bring you a fine head you can have flattened. Or better go buy the high compression head at Snyders or others.
Joe K
Shudda kept the horse.
Old 01-15-2014, 12:18 AM   #13
Brother Hesekiel
Brother Hesekiel's Avatar
I have a LB engine, which reportedly stands for Long Beach Ford.
Yes, a diamond engine is desirable: http://pvmac.org/phpbb/viewtopic.php?f=9&t=23
Brother Hesekiel is offline   Reply With Quote
Old 01-15-2014, 08:13 AM   #14
Tom Wesenberg
Yes, my head was cracked just as Joe described, when I bought my 28, but the block was perfect.
I bought a nice looking short block at an auction years ago, but after cleaning it up I found a freeze crack in the valve chamber.
