Old 10-10-2020, 02:35 PM   #1
drolston
drolston's Avatar
Default Vacuum Brake on a Crab
On a rebuilt crab distributor, the piston seems a little sticky in the bore. How easy should the piston move? Should the piston be lubed or stay dry? There was some grease on the leather pad; what should that lube be?
How do you adjust the brake to retain a light damping of the breaker plate?
Old 10-10-2020, 02:55 PM   #2
51woodie
51woodie's Avatar
Default Re: Vacuum Brake on a Crab
Check this link to Bubba's Ignition. The piston should move freely and be lubed. Look closely at the distributor that Bubba built for me, and you will see that he uses a liberal amount of HI-temp grease on the piston, leather and points rub blocks. The info in the link describes the piston adjustment.
http://www.bubbasignition.com/crab-42-48.html
51woodie is offline   Reply With Quote
