Old 09-24-2020, 02:23 PM   #1
Tinbasher
Tinbasher's Avatar
Question 28 7 tooth Steering gear
Does anyone know if an adjustable lower bearing is available. I have replaced the bearings, the worm gear, the sectorshaft. Rebuilt the end of the steering shaft, etc. etc. but I still have about 2" of lash in the steering wheel.
I thought I had hear of someone that was making this piece to replace the lower bearing.
Any Ideas?
The Old Tinbasher.
Tinbasher is offline   Reply With Quote
Old 09-24-2020, 03:04 PM   #2
Werner
Werner's Avatar
Default Re: 28 7 tooth Steering gear
Tinbasher,
have you adjusted correctly the end-bearing play of the lower plate with several brass seals tightly? If that has too much space (1/100 "), then it is more than 3 finger widths on the circumference of the steering wheel. You can see that when the steering wheel shaft moves slightly up and down when you turn the steeringwheel slightly to the left and right.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-24-2020, 05:29 PM   #3
Synchro909
Synchro909's Avatar
Tinbasher,
I suspect your problem is not the adjustment of the bearings on the worm. It is more likely to do with the wear in the worm and sector. The sector shaft bearings are also likely in need of replacement.
There is no point repairing or adjusting one part of a steering box without the rest. All components wear and it only takes a little wear to get the free play you have.
When you rebuild it properly, I suggest you use eccentric sector shaft bushes to get the best worm/sector engagement possible.
Old 09-24-2020, 07:13 PM   #4
Ranchero50
My steering wheel shaft was moving axially in the housing. Ditched the spacers and paper gasket and everything came back into tolerance.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 09-24-2020, 10:00 PM   #5
GRutter
GRutter's Avatar
If you replaced worm and sector, then be certain that the steering shaft is not moving up and down as you turn it. That would be an indication that there are too many shims on the bottom of the steering housing. There isn't any other adjustment for gear mesh on the 28-29 box. Make certain that the sector shaft end play is adjusted correctly. Did you also replace sector shaft bushings and hone to fit (or replace with needle bearings?) I have seen some sector shafts that are undersize.
GRutter is offline   Reply With Quote
