Old 05-13-2016, 03:00 PM   #1
rnch
Default What's better: cork or rubber valve cover gaskets...
.....for my '65 352 engine?
rnch is offline   Reply With Quote
Old 05-13-2016, 03:33 PM   #2
Lanny
Lanny's Avatar
Default Re: What's better: cork or rubber valve cover gaskets...
Try to rip a cork one in half.
Then try to rip a good rubber one in half.
I would use a good rubber gasket
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 05-13-2016, 03:42 PM   #3
darrell
you can also reuse a rubber gasket
darrell is offline   Reply With Quote
Old 05-13-2016, 05:54 PM   #4
prpmmp
I was taught to grease up a cork gasket and been doing it for years with real good results!! Pete
prpmmp is offline   Reply With Quote
Old 05-14-2016, 07:39 AM   #5
mikhett
Best valve cover gaskets I have found are REAL GASKETS.MADE IN TENNESSEE. THEY SOLVED MY 390 FE VALVE COVER LEAKS.NO LEAKS SINCE 2007.
mikhett is offline   Reply With Quote
Old 05-14-2016, 07:53 AM   #6
Hot Rod Reverend
Hot Rod Reverend's Avatar
Rubber gaskets are good for y block valve covers because of making valve adjustments along the way and the gaskets are reusable for sure.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 05-14-2016, 07:55 AM   #7
Ole Don
Ole Don's Avatar
First, you need a rocker cover that is flat on the bottom. Then, it must be clean. Sandpaper it clean, shiny metal clean. Test fit a cork gasket to make sure its right, then attach the cork with 3 M trim cement. Let if set, then spray the cork with WD 40. Let it sit, then spray it again until it is saturated. Install the rocker cover to a clean surface, and do not over tighten the fasteners. It will not leak, and it can be removed and replaced a number of times over several years.
Ole Don is offline   Reply With Quote
Old 05-14-2016, 08:56 AM   #8
bobss396
bobss396's Avatar
I have Dart heads on my Ford, bought a whole top end kit. Their gaskets are cork, but 2X thicker than regular ones.
I glued them to the valve covers with RTV and am using nothing on the head mating surface. I use spreader clamps and actually torqued the bolts.
The rubber ones are okay too, those you can adhere to the covers. The biggest sin is over-torquing them and bending the thin covers.
bobss396 is offline   Reply With Quote
Old 05-15-2016, 10:59 AM   #9
Ole Don
Ole Don's Avatar
Young guys need to print out the last sentence from Bobss396 post, then staple it to the wall in sixteen places.
Old 05-15-2016, 12:30 PM   #10
Hot Rod Reverend
I have lost track on the number of valve covers I have fixed over the years after seeing that some gorilla had turned them into bananas!!!!
Old 05-15-2016, 08:50 PM   #11
bobss396
bobss396's Avatar
Learned the hard way. I never torqued valve covers in my life until this build, looked it up and went by the numbers. So far so good.
Old 05-17-2016, 04:36 PM   #12
hardlyrider
hardlyrider's Avatar
Someone told me ramshorns are h**l on the lower part of the valve cover gasket. Which material holds up better to the heat?
hardlyrider is offline   Reply With Quote
Old 06-03-2016, 05:30 PM   #13
rnch
Yup! When I changed the leaking one yesterday; i held up a small metal ruler on the lip; had to "adjust" two high spots due to someone cranking down too hard.
I used new lock washers and torqued 'em down to the factory shop manual specs....and NO tighter.
Old 06-03-2016, 06:27 PM   #14
Alaska Jim
Alaska Jim's Avatar
did you use a flat washer between the valve cover and the lock washer? doing so, will help to keep the valve cover from deforming.
Alaska Jim is offline   Reply With Quote
Old 09-10-2020, 02:16 PM   #15
greenpondmike
I have used rubber, cork/rubber and cork. The unimproved pure cork fel-pro gaskets work the best and have reused the present one 3 or 4 times. I just stagger tighten them from front to back and back to front and then do a final recheck the same way. I use a 1/4 drive ratchet and hold it at the head with just a little thumb pressure on handle near the head. Works great and since I'm not the sharpest tool in the shed I pray and I get some good answers on how to do stuff.
Edit: From my understanding the improved cork is the cork/rubber one--I used it and was not impressed. Sometimes old teck is the best teck.
greenpondmike is offline   Reply With Quote
Old 09-11-2020, 09:03 AM   #16
54vicky
54vicky's Avatar
I am pretty sure they figured it out by now post is 4 years old
54vicky is offline   Reply With Quote
Old 09-11-2020, 11:06 AM   #17
Lanny
Lanny's Avatar
The original poster has been waiting for the last reply
Old 09-11-2020, 06:15 PM   #18
greenpondmike
Lol, I just don't know how y'all got along without me. Nah, I knew the post was old, but I just wanted to throw in my $0.02 and plus it would put it back on top so y'all could come back and rag me a little. Hello to y'all...
Old 09-11-2020, 08:13 PM   #19
Lanny
Lanny's Avatar
Hello, back at ya. Welcome to the Barn..
Old 09-12-2020, 02:13 PM   #20
greenpondmike
Thank you Lanny
