Old 07-22-2020, 09:46 AM   #1
Tom's36coupe
Tom's36coupe's Avatar
Default New rubber for rod from radiator
Want to replace the rubber donuts on the hood rods that bolt from the radiator to the firewall. My car is a 36 coupe, Can't seem to find them, any idea on who might? Thanks!
Tom's36coupe is offline   Reply With Quote
Old 07-22-2020, 11:57 AM   #2
Brian
Brian's Avatar
Default Re: New rubber for rod from radiator
Can you not simply use two different sized hollow punches to punch rings out of some rubber, and sandwich them together?
Old 07-22-2020, 02:06 PM   #3
Don Rogers
Don Rogers's Avatar
35-36 exhaust mounting hardware uses the same rubber washers
Don Rogers is offline   Reply With Quote
Old 07-22-2020, 02:39 PM   #4
Randy in ca
Randy in ca's Avatar
Says they're in stock:
https://cgfordparts.com/ufolder/ford...er=40-5283/4-2
Randy in ca is offline   Reply With Quote
Old 07-22-2020, 03:57 PM   #5
Tom's36coupe
Perfect, thanks so much! Forgot about C & G Ford parts
Old 07-22-2020, 07:10 PM   #6
RKS.PA
RKS.PA's Avatar
Kyle, Joe, and Dorothy are there for us!!
RKS.PA is offline   Reply With Quote
Old 07-22-2020, 07:12 PM   #7
RKS.PA
RKS.PA's Avatar
By the way, that's on BEAUTIFUL engine compartment....and car too!!
Old 07-23-2020, 12:01 AM   #8
Russ/40
Russ/40's Avatar
What intake is that? Carbs are backwards?
Old 07-23-2020, 11:25 AM   #9
Tom's36coupe
Russ/40, Its an original Hexagon tool from Dearborn. Good friend who built my motor and then did some hot rodding with me on it found the intake at a swap meet years ago. Always gets attention at shows! My dad bought the car in 1972 and have had it all these years. Before he passed away it became my 36! Its been at the painters for 7 years, finally back home and getting back together. With the help of the Fordbarners for sure! lol...RKS. PA, thanks!
Old 07-23-2020, 11:32 AM   #10
Tom's36coupe
One more picture for you
Old 07-23-2020, 07:12 PM   #11
aussie merc
aussie merc's Avatar
yeh just noticed that they are backward tells me its likely a marine manifold but who cares if its not on an anchor looks great and as you say gets the looks
aussie merc is offline   Reply With Quote
Old 07-24-2020, 05:47 AM   #12
KGS
KGS's Avatar
Here's a link to some info on the Hexagon manifold
plus some other interesting trivia.
http://myflatheadford.com/hexagon-tool-intakes/
KGS is offline   Reply With Quote
Old 07-24-2020, 06:41 AM   #13
Tom's36coupe
KGS, thanks for the link on Hexagon....pretty cool to have one. I had mine polished a few years ago and really shines now.
Old 07-24-2020, 01:23 PM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
Don, that's good to know. The last time I installed exhausted hanging hardware on my 35, I thought those rubber washers looked familiar and/or used somewhere else on my '35's. Now hopefully I can remember that if the need ever arises.
John
