03-03-2019, 07:49 AM | #1 |
T5 Speedo question
I’m in the process of getting the parts ready to fit a T5 into the Cabriolet and would like to know how others have sorted out the speedometer problem.The trans I am intending to use has the electronic speedo version.I would like if at all possible to keep my original speedo and don’t want a gps one either.
I’m guessing an electronic aftermarket speedometer is going to be the answer but thought I’d throw it out there to see what others have come up with. |
03-03-2019, 09:10 AM | #2 |
Re: T5 Speedo question
Speedhut makes a unit that allows you to connect a mechanical spedo to a trans that has an electronic drive. Google Speedhut.com
03-03-2019, 09:18 AM | #3 |
Here is the link
https://www.speedhut.com/ecommerce/p...peed-Converter |
03-03-2019, 10:16 AM | #4 |
That’s a nifty little thing
03-03-2019, 11:35 AM | #5 |
There is an advertiser on the Hamb that converts your electronic tail shaft to a mechanical. Or, just find a mechanical tail shaft T5 and swap it out. In either case in my old 40 coupe with T5 I was able to use the stock 40 speedo cable and if memory serves me it was about 5mph off .... but that all depends on rear gear, tire size. Now, to be truthful, I use a cheap eBay purchased used Tom Tom and my speed is calculated by it.
03-03-2019, 12:01 PM | #6 |
03-03-2019, 01:58 PM | #7 |
Abbott industries make a speedometer adapter electronic in to cable out .http://www.abbott-tach.com/cablex.htm
I think these are USA made . Great unit , but a PIA to calibrate but once you are done calibrating to get the exact speed you are done. Or this way , a hidden Sky drive unit with a cable drive out put . https://www.classicautoinnovations.com/ Last edited by my4dv8; 03-03-2019 at 02:05 PM. |
03-03-2019, 02:39 PM | #8 |
I've had a cable X box for about 4 years. Works perfectly!
