12-17-2021, 11:22 AM | #1 |
1940 ford walker shroud
my good friend john mounted my walker ws40 shroud to my 40 radiator ,the shroud fit inside of wire loom and brackets mount with machine screws the hole is 1'' larger than the fan , the shroud sits flush to radiator, thank you john for your exellent work
12-17-2021, 11:34 AM | #2 |
Re: 1940 ford walker shroud
T he shroud looks to be black plastic mounted to alum brackets.
Any idea where your friend got the shroud? |
12-17-2021, 11:45 AM | #3 |
the shroud was mine and made by walker radiator co.no longer in business its made of polypropline cut with a jig saw
12-17-2021, 11:48 AM | #4 |
Nice piece
I'd like to find one like that |
12-17-2021, 12:03 PM | #5 |
i placed an ad on here in the wanted section about a year ago and a fellow barner had a NOS one uncut in the box , hopefully a company will buyout walkers the tooling and start making radiators and shrouds again
12-17-2021, 01:01 PM | #6 |
Fortunately, Johnson's Hot Rod Shop has picked up the Walker business. I don't know if they'll be offering the shrouds too, but you could check with them: http://johnsonshotrodshop.com/news.php Good Luck
Seabright Hot Rods |
12-17-2021, 01:18 PM | #7 |
I have one on my 39. Works great.
12-17-2021, 02:57 PM | #8 |
Ditto what Jack said.
Charlie ny |
12-17-2021, 03:24 PM | #9 | |
12-17-2021, 06:33 PM | #10 |
Nice job. Shroud looks good.
When I installed my 1940 Walker shroud on the 1940 Walker radiator, I cut it in half horizontally so it would be easy to remove without having to remove the fan. You can't see the cut line in the photo but, it's there. |
12-17-2021, 06:54 PM | #11 | |
12-17-2021, 07:27 PM | #12 |
Still available from:
Cooling Components, LLC Memphis, TN 901-336-6194 [email protected] Cooling Conponenets was founded by Walker Radistor in 1993, in 2011 Cooling Components split off from Walker and are still in business. |
12-17-2021, 08:03 PM | #13 |
I have a Walker radiator with a Cooling Components electric fan and shroud in my '32 roadster with buick nailhead 401,....no issues, great cooling.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
12-19-2021, 11:20 AM | #14 | |
12-19-2021, 06:37 PM | #15 |
Another option should be Vintage Air, the air conditioning folks. I could not open their catalog but did notice Speedway Motors offers plastic shrouds fron Vintage Air. Hope this helps.
12-19-2021, 08:53 PM | #16 |
If you can close off the bottom part, the shroud will work better. The less open space around the shroud the better it works.
12-20-2021, 06:07 AM | #17 |
I went to allot of trouble to construct an aluminum shroud for my 40 Ford with A/C. I found the problem with the full coverage shroud was the restricted air flow at speed. I first cut some windows with flapper doors so they would open with pressure. Eventually I found that using no shroud was OK with my setup.
12-20-2021, 01:54 PM | #18 |
I have a Walker Radiator with Cooling Components fan and shroud in my 40 standard. Works great.
