Old 10-20-2017, 06:03 AM   #1
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Timing gear torque.
When I put 100 ft lb on that nut to tighten it, should I use a rag in the teeth or will the fiber teeth handle it? Don't want to mess up a new gear.
Jacksonlll is offline   Reply With Quote
Old 10-20-2017, 07:36 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Timing gear torque.
Jackson, my Man,
Someone holding with the crank, will allow you to torque it to 100 Ft Lbs! Daves' Wife held it for him DON'T MESS with that WOMAN!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-20-2017, 08:45 AM   #3
Big hammer
Thw rag trick will let you torque the nut, BUT you will need a dentist in the future to repair broken teeth! Put the car in gear, chock the wheels with big chocks. Maybe using a rattle gun would work with guessing how tight to get it ?
get a bigger hammer tap done
Old 10-20-2017, 09:08 AM   #4
Ray in La Mesa
I wedged a 2"x4" between the block & crank, it worked great.
Ray in La Mesa is offline   Reply With Quote
Old 10-20-2017, 10:21 AM   #5
Jacksonlll
Jacksonlll's Avatar
Ok, I'll do it that way, but it means I load up those fibres gear teeth. They must be strong enough. Thanks
Old 10-20-2017, 10:39 AM   #6
Fullraceflathead
Fullraceflathead's Avatar
I wouldn't want to put that kind of stress on the teeth. Put the car in high gear with the hand brake on tight
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 10-20-2017, 10:46 AM   #7
Jacksonlll
Jacksonlll's Avatar
Same thing. The crank gear holds the fiber gear. No way to hold just the cam. It must be ok.
Old 10-20-2017, 10:47 AM   #8
glenn in camino
glenn in camino's Avatar
I would use an aluminum or bronze gear.
glenn in camino is offline   Reply With Quote
Old 10-20-2017, 11:16 AM   #9
George Miller
George Miller's Avatar
The only good way to do it is take the side cover off and put a clamp across the gear below the teeth. The rag puts pressure on the teeth just like no rag.
George Miller is offline   Reply With Quote
Old 10-20-2017, 11:41 AM   #10
Bob C
I believe Dan McEachern recommends the same as George.
Bob
Old 10-20-2017, 11:57 AM   #11
29spcoupe
29spcoupe's Avatar
Why not use an impact wrench? John
29spcoupe is offline   Reply With Quote
Old 10-20-2017, 01:59 PM   #12
Patrick L.
Patrick L.'s Avatar
A rate gun rattles the gear worse than the rag.
Old 10-23-2017, 12:33 PM   #13
Jacksonlll
Jacksonlll's Avatar
New question. I saw on a video where the guy put a big washer on before he put the nut on. Is this right? Snyder's does not offer one. Help.
Old 10-23-2017, 01:42 PM   #14
George Miller
The nut has a lot area to contact the gear. No washer needed.
Thread Tools
Display Modes
