07-28-2017, 07:33 AM | #1 |
Running with out shocks
Hi All,
I have a 1930 Coupe that I drive a fair amount. It has No Shocks. I try and keep the tire pressure @ 35psi. I plan on putting shocks on her as soon as I can afford it. In the mean while should I be greasing the leaf springs as they are working extra hard now? She is a handful right now if the road is irregular but I keep her under 40 mph most of the time. TIA Chris Union, ME |
07-28-2017, 07:52 AM | #2 |
Re: Running with out shocks
Without shocks you are finding control hard and you can break a spring if you hit a pothole, go over a railroad track or a similar situation that tosses the car upwards in a rebound. All the spring leaves take the load downward, but upward the main leaf carries the load so watch out for rebounds.
07-28-2017, 08:15 AM | #3 |
Having shocks on a Model A will improve the ride. The Model T was not equipped with shocks and when the Model A was being developed the story goes that Henry Ford went for a ride in a prototype and then told the developers to add the shocks from the Lincoln. The Model A was the first car in it's price range to have shocks. So don't be afraid to drive the Model A until you can afford shock, do go with the original style either from Brattons or Specialty Motor Cams unless you have rebuild-able originals.
07-28-2017, 08:51 AM | #4 |
Shocks will dramatically improve the ride and handling. I have driven a 28 pickup 12,000 miles without shocks and have not had any ill affects. I have driven other Model A's and then put shocks on them and the ride is so much nicer and handling is better. You don't have to overthink the springs, when you get shocks just put them on and you will enjoy the new feel.
07-28-2017, 09:28 AM | #5 |
There are a lot of Model A's out there running around without stocks that also have weak springs and front ends that really need rebuilding.
You know you have a car that is not "SAFE". If you can't afford to fix it, please don't endanger your self and other people. Make it safe and enjoy a great little car. |
07-28-2017, 09:32 AM | #6 |
Wayne @ Barb Malvern '19 T Speedster '26 T Touring '29 A Roadster '30 AA Stakebed '30 A Pickup '30 A Town Sedan '31 A Station Wagon '38 Columbia Girls bike (WWII) '40 Elgin Boys bike (WWII) '42 Super Deluxe Tudor '42 Willys MB Jeep '43 Willys MBT Trailer '43 M3A4 Hand Cart '43 Harley Davidson 42WLA with sidecar |
07-28-2017, 09:55 AM | #7 |
Drove my fordor without shocks and rebuilt springs.
Drove it once and felt the car unsafe over 20 MPH and never drove without shocks again. |
07-28-2017, 10:05 AM | #8 |
My experience is similar to Kevin's.
50 years ago someone told me NOT rebuild springs until I got the shocks "in hand". My suggestion is to wait until you get the shocks before you lube the springs ... After you lube the springs you WILL likely need the shocks as the car will bounce around more. The stiff springs now are acting like shocks and dampening the suspension to some extent ! I should note that I drove the coupe with no shocks and rusty springs for 40,000 miles before I got shocks and rebuilt the springs. Last edited by Benson; 07-29-2017 at 05:18 AM. |
07-28-2017, 10:20 AM | #9 |
I recently put on some modern rear shocks and they really helped the control. The bounding and body roll was coming from the rear it seems. so much so that I dont know if I need to do the fronts now. the fronts are presenting more of a problem as the steering is there and I dont want them visible. I welded tabs onto my axle with some 1/2 in steel I had around. works great perfect amount of resistance and travel. gabrial classics. ill edit this post with the photos and ebay listing if still available. photobuckets new policy invalidated my shock thread or I would have posted that too. not saying that my method is the best for everybody or better than a kit you can buy. but it was super cheap free steel and 30$ per shock and 8$ for a shock. a double eye shock may be better for this positioning as wel. For this to work the upper hole is oversized to allow movement. http://www.ebay.com/itm/380664692481?rmvSB=true
07-28-2017, 12:55 PM | #10 | |
Sounds like you have it all in hand and under control with a plan, so just follow thru when you can . Just went to a Model T swap meet. Not only did that model not have shocks, but they also did not have other 'things' that you do have on your Model A...namely front brakes . How do you like your Model A now ! |
07-28-2017, 02:07 PM | #11 |
I drove my Tudor for years w/o shocks. I bought a set of friction shocks off the swap meet, and I must say its like night and day for the better.
07-28-2017, 02:31 PM | #12 |
All the AA's did have front shocks - most didn't have the rear except very special vehicles like ambulances and hursts. With no load nowadays and slow speeds AA's go they arent needed at all...
1929 Model AA - Need long splash aprons! |
07-28-2017, 02:34 PM | #13 |
Gives you confidence in the handling of the car
07-28-2017, 02:53 PM | #14 |
The stock shocks are very good, but if you're short money, don't overlook the dry friction type. Speedway has some offenhauser brand that are simple bolt-ons, and pretty reasonable. You may need to buy the ball as well as the shock. The dry shocks aren't fantastic, but they're fantastic compared to nothing.
07-28-2017, 07:47 PM | #15 |
Huh! Look at that? I poked my head under my newly purchased 29 Tudor and found that it doesn't have any shocks! Why would someone remove them? It looks like I'll be in the market for a 'complete kit'.
Do I just go with one of the modern shock setups or try to piece together a original style kit. Maybe I'll look into the dry shocks? *edit* How much for a complete set of 'originals'?! $1180.00!? Yowza. Fun stuff! Ted Last edited by TRP; 07-28-2017 at 08:05 PM. |
07-29-2017, 09:39 PM | #16 |
Model A shocks are all over the place in quantity, quality, price and phonies abound. Couple of the crap repops on my pickup were doing nothing. The Ford script may be the clue that they are the no refill crap. Since I go to many swap meets, I learned to test the low cost cores offered out here(California) with my hands and soon was able to spot cheap shocks that would function. None are over $25 and many less. Now the pickup is well shocked but suffer a bit of leakage that I must top off occasionally. Many millions of the Model A shocks were made and there is little shortage. Think of it as a hands on sport. Good Luck: Fred A
07-30-2017, 12:34 AM | #17 |
I have best experience with new shocks from Bill Stipe. They look identical to my originals, which were no more functional and are refillable. The riding improved tremendeously. With springs greased and covered, the car keeps the lane also on rough roads up to high speeds ( 55-60 mph). Itīs a piece of cake to handle the car on a highway even for my wife.
07-30-2017, 01:59 AM | #18 | |
Guys are talking friction and old worn out leaking originals and no shocks at all. If you are not into authenticity...try MG shocks. I put rebuilt front MGs on my '30 roadster and they are incredibly good at bounce control ! MG fronts/rears are different. They can be had off of ebay REBUILT for cheap compared to questionable rebuilt originals...if you can find them. |
07-30-2017, 07:35 AM | #19 |
Ever drive an OLD Buick, with coil springs & NO shocks??? You'll get SEASICK & they're DANGEROUS & on hard braking, they do UNBELIEVABLE rear wheel HOPPING!!!
Bill Reallyscared
07-30-2017, 09:17 AM | #20 | |
