02-10-2011, 08:16 PM | #1 |
Generator issues
Hi Folks:
Installed a rebuilt generator and new cutoff switch with diodes. When I try to set the third brush I can only get either a +20 or higher or 0 reading on the ammeter. If I turn on the headlights the reading goes to +8 add the horn and it goes to +4 when it is set to +20. When set at 0 it goes negative. I also did the hot wire to make sure the polarity was correct. Any ideas? Thanks, Marshall |
02-11-2011, 01:44 AM | #2 |
Re: Generator issues
So no one is confused I know you meant "CUTOUT" when you said "cutoff switch", and you have a diode type cutout. Are you moving the adjustable brush in very small increments? I know they can be tricky and you may be moving the brush from one extreme to the other. I like to use an insulated screwdriver and use the generator case opening as a pivot point, so you can get some nice leverage to make small adjustments.
Personally I never use an adjustable brush but use my EVR, which fits in place of the adjustable brush and it's holder. If you are able to make small brush adjustments, but the amp guage still only shows 0 or 20 amps, I'd check for a poor connection somewhere in the charging circuit. |
02-11-2011, 12:44 PM | #3 |
It is possible the movable brush is wired to the output instead of to the field ? When the insulated brushes are reversed wired you get full charge and no control of charge rate.
Ron |
02-11-2011, 03:06 PM | #4 |
