Old 01-22-2015, 05:48 AM   #21
Gerald1961
Gerald1961's Avatar
Default Re: 1929 Briggs Town Sedan Interior Pictures
Super Photos, Marco!
Could you please a add close-up of the chrome parts? Are they original stock parts? They are different from 30/31 to S/W, but a close look would be fine!
Thanks in advance
Gerald
Gerald1961 is offline   Reply With Quote
Old 01-24-2015, 12:08 AM   #22
Marco Tahtaras
Marco Tahtaras's Avatar
Thanks in advance
Gerald
Unfortunately those were older photos sent to me from Scott McGrew (his car) so they can't be blown up. The handles and escutcheons are considerably different. I went through pics I have for the proper handles and none are good enough to tell much.
It's worth noting that the correct finish is Butler or satin nickel which has a much richer appearance than chrome (in my opinion) but not many folks do it.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-24-2015, 01:51 AM   #23
burner31
burner31's Avatar
Skibb:
Looks like your at where I'm getting ready to go.
Keep us all updated on the progress.
Believe it or not...it helps us all.
Keith
Shawnee OK
'31 SW 160-B
Old 01-24-2015, 02:51 AM   #24
Gerald1961
Gerald1961's Avatar
Thank you, Marco for searching!
Nevertheless, I think I will try carefully glass bubble blasting nickel plated parts. I have to buy a spare "test" part to see how even it can be made ...by hand. Glass bubble blasting companies are not far from my home as well as a nickel and chrome plater. I will report any progress. I will start end of march when I unpack our Lady from her winter clothes...
best regards,
Gerald
Old 07-21-2017, 05:44 AM   #25
Gerald1961
Gerald1961's Avatar
Talking Re: 1929 Briggs Town Sedan Interior Pictures
Hello togehter,
i want to update this thread because I finally continued my restauration work on the chrome interieur parts. Unfortunately, swap meets in Europe donīt give any possibility to buy used Model A parts because its too seldomly driven in Eu.
But I always thought about a possibilty to get my interieur butler finished. My thoughts ended up -- as said before- in mechanically treat my glossy chrome parts instead of chemical treatment. I finally bought a sand blasting system an 0,05 - 0,4mm quartz sand and tried to sandblast carefully the surfaces. I am absolutely happy with the results, in my opinion there is no visual difference to rebutlered parts.
Old 07-21-2017, 09:17 AM   #26
1930artdeco
1930artdeco's Avatar
Gerald, those look great! I like them and when I redo my car I will have to find a way to get that finish.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-21-2017, 09:53 AM   #27
Gerald1961
Gerald1961's Avatar
Mike, thank you very much! I am really proud of my work. But honestly spoken, it was a very simple job. You will succeed easily!
Gerald
Old 07-21-2017, 12:21 PM   #28
burner31
burner31's Avatar
Did you treat or coat the items blasted to prevent rust?
Keith
Shawnee OK
'31 SW 160-B
Old 07-21-2017, 12:24 PM   #29
burner31
burner31's Avatar
What's with the watch in pic 4
Keith
Shawnee OK
'31 SW 160-B
Old 07-21-2017, 02:24 PM   #30
Gerald1961
Gerald1961's Avatar
Hi Keith,
i took the original chrome plated parts and blasted VERY carefully. Apprx. 5s on a certain spot, then the surface turned matt. I am pretty sure not to have injured the closed chrome surface.
My chinese automatc watch I put aside not to sandblast it too. I did the whole operation without gloves.
Gerald
