04-12-2021, 03:32 PM | #1 |
tranny issue HELP please
so ive got a 59 Edsel with the 292 and a two speed auto trans. trans shifts great..takes gear great..fluid is nice and clean, problem is,,it's spitting fluid back out via the filler tube...what am i looking for to stop that? anyone help? Never seen this before. Thanks in advance
04-12-2021, 05:17 PM | #2 |
Re: tranny issue HELP please
the breather screen is pluged causing it to build up pressure.
04-12-2021, 06:38 PM | #3 |
I think he means the air vent is plugged. The air vent is located near the top of the trans case and it has a cap on it. The vent can be removed with a wrench and soaked in solvent and blow out with compressed air. Then re-install the vent and it should be okay.
04-13-2021, 07:27 AM | #4 |
thank you to daves55 and darrell for the input! i will look into this issue TODAY. I really appreciate the help. Im dying to drive this old car. THANK YOU AGAIN.
04-13-2021, 07:54 AM | #5 |
Does this happen just after start or is it more or less continuous?
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
