Old 02-23-2021, 08:34 PM   #1
Baggs
Default What hub/drum assy do I have here?
N/m, cant get a pic uploaded
Baggs is offline   Reply With Quote
Old 02-23-2021, 08:53 PM   #2
JSeery
JSeery's Avatar
Default Re: What hub/drum assy do I have here?
If you wand them upload while you work on figuring out how to post, I'll post them for you. [email protected]
Several threads with detailed, step-by-step instructions.
Old 02-24-2021, 02:25 AM   #3
Baggs
Thanks,
Seems I need to get a resizing application.
Will send you the pic.
Thanks again,
Mike
Old 02-24-2021, 04:40 AM   #4
36coupe
36coupe's Avatar
I Email them to myself and pick a small size when I send them
36coupe is offline   Reply With Quote
Old 02-24-2021, 01:33 PM   #5
JSeery
JSeery's Avatar
Originally Posted by Baggs View Post
Thanks,
Thanks again,
Mike
Yes, the file you sent me was 3.27 MB and the maximum size you can post (per the limits listed in the pop-up menu). This is 120KB. What computer are you using, or are you doing everything on your phone? I also cropped the photo removing the space at the bottom and top.
Old 02-24-2021, 02:21 PM   #6
rotorwrench
rotorwrench's Avatar
Ford made two types of 12" X 5" on 5.5" lug pattern drums from 1940 thru 1948. The earlier drums were wide 5 pattern. The earlier ones of the two types had the hub mounted on the inside of the drum and the later ones had the hub on the outside of the drum. It certainly could be the inny type or perhaps an aftermarket replacement.
A photo may not tell the whole story. Measurements and characteristics say more than a photo. For example, I can't tell the drum braking surface diameter or the lug pattern size from the photo. An 11" braking surface drum would be later if the pattern is 5" on 5.5".
Old 02-24-2021, 03:26 PM   #7
Baggs
First, thanks to jseery for posting the pic for me
The BP is 5 on 5.5. I ran a tape on the other side w/o a hub that has the shoes on it, and appears it’s for a 12 inch hub. The shoes are 1 3/4 inches wide.
Thanks.
Old 02-24-2021, 03:30 PM   #8
Baggs
I figured out last night reading another members reply about editing the pic in Paint, it worked, but seems since I was at work there was a security issue in posting the file. I was on the secure network, probably what the issue was there. The member also posted how to make the pic smaller on my phone, but for some reason I can’t download an app on it.
And again, I thank you for your help!
Old 02-24-2021, 03:33 PM   #9
Mart
Mart's Avatar
It's what I'd call a "40" hub. Drum fits over the hub. (Hub is on the inside).
Brakes are 12x1.75"
Later had the hub on the outside but off the top of my head I'm not sure where the switch point is.
As a point of interest, the hubs/drums as an assembly are interchangeable for any year 1939 to 1948
Mart.
Old 02-24-2021, 03:46 PM   #10
19Fordy
19Fordy's Avatar
It looks like this 1940 Ford front drum.
Old 02-24-2021, 05:02 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Your drum pictured below is what I believe to be an
"aftermarket replacement" drum/hub assembly for 1940 and '41, like in 19Fordy's pictures above this post.
An original '40-'41 drum has these bumps or scallops like in the pic below. DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 02-24-2021, 06:43 PM   #12
19Fordy
19Fordy's Avatar
Thanks V8 for that tid bit of info.
I always thought the OEM brake drums were smooth like the ones that were on my 40 in 1963. Here is a photo of that same drum/hub assembly. Can you make out the part number. The Ford parts book shows Ford Part Number 01A-1105-A for 1940-41 Ford. Cost was $6.25 for "Hub-Front & Drum". Gee, that was a lot of money in 1940.
The Hub-Rear & Drum shows Ford Part # 01A-1115-A and cost $7.50 in 1940.
Old 02-24-2021, 07:23 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Hey Jim....You know, you MAY have a point there. I said "I BELIEVE...", which actually means "WTH do I REALLY know?" You surely know that "01A" means "1940-First Issue". The "-A" means "Passenger Car". The "1106" is Ford language for "front hub/drum ASSEMBLY"...you could NOT buy a drum from Ford separately. The "-A2" at the end means some sort of update or change. So, with that type of part number forged into that hub flange, it is likely a Ford replacement assembly, or merely a later production assembly used on some '40 or '41 cars and light pick-ups. But remember...what do I know? DD
T5 W/TORQUE TUBE
Old 02-24-2021, 07:44 PM   #14
19Fordy
19Fordy's Avatar
V8: Thanks for the clarification. Your reply made sense to me.
Old 02-24-2021, 08:11 PM   #15
Baggs
I appreciate all the replies, assuming an aftermarket assy, and trying to achieve symmetry, is my best bet for a 40-41 assy?
Old 02-24-2021, 08:16 PM   #16
JSeery
JSeery's Avatar
See this current thread: https://www.fordbarn.com/forum/showthread.php?t=294942
Old 02-24-2021, 08:31 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
YES! Boling Bros. also have the only quality, 'stock-like' drums available. Do NOT use the Speedway drums which look similar to the Boling Bros. drums. They have had several problems. Boling drums replace the same way as that repro Buick drum. Replace the studs by reaming for .600" Dorman 610-234 studs, and voila! Same deal....contact Gary at Cornhuskers. DD
T5 W/TORQUE TUBE
Old 02-24-2021, 09:24 PM   #18
Baggs
Thanks,
Issue I have is the other side is without the hub/drum assy, just a spindle and backing plate and brake hardware.
I have an hydraulic braked axle out back, but hate to pull it apart as I can't get it in and out of the weather.
SO looks like I'm in the hunt for a 40/41 hub/drum assy.
Sure wish the swaps would open soon
Old 02-25-2021, 01:46 PM   #19
Ggmac
Thanks,
Where do you live ?
Old 02-25-2021, 01:47 PM   #20
cas3
you should have you're general location in you're avatar, perhaps there is one near home
cas3 is online now   Reply With Quote
