Old 01-15-2022, 08:30 PM   #21
daren007
Default Re: Installing Radius Rod Rubber Ball
Just fix it right.
daren007 is offline   Reply With Quote
Old 01-17-2022, 10:02 AM   #22
Brendan
Brendan's Avatar
first thing is to drill a hole in the end of the ball
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-23-2022, 06:45 AM   #23
twostickmutt
Originally Posted by Ed in Maine View Post
Today I put the rubber ball on the freshly painted radius rod/front axle. After about 45 minutes of trying to get the ball to go on with a little liquid soap, I felt there had to be an easier way. There is! I took a plastic bottle and cut out a cone shape. The small end goes into the rubber ball and the large end goes over the radius rod ball. Just push, the cone opens the rubber ball equally all around and it easily goes over the steel ball. Before it goes on all the way, take out the plastic cone. It worked the first time in less than a minute. Ed
i know this is a very old post but today i tried the plastic bottle/funnel trick. it worked in a heartbeat. i tried several tricks that i've read here but this was the best for me. thanks for posting.
twostickmutt is offline   Reply With Quote
Old 01-24-2022, 06:59 AM   #24
brokenspoke
Originally Posted by Mike View Post
I would not use the rubber ball setup, call brattons and get the original radius rod set up
Mike
What is original?
brokenspoke is offline   Reply With Quote
Old 01-24-2022, 07:59 AM   #25
Redbird
Redbird's Avatar
Good one with the spoons!
Redbird is offline   Reply With Quote
Old 01-24-2022, 10:57 AM   #26
chrs1961815
chrs1961815's Avatar
Originally Posted by brokenspoke View Post
What is original?
Just a steel ball, you can weld up worn spots and file back to a somewhat round shape.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
