Old 01-08-2022, 10:46 AM   #1
farmertom
farmertom's Avatar
Default battery disconnect
which style do you folks use and do you install on pos grnd battery post? or not use at all. Tom.
farmertom is offline   Reply With Quote
Old 01-08-2022, 10:58 AM   #2
19Fordy
19Fordy's Avatar
Default Re: battery disconnect
I have been using this style for the past 20 years with no problems. It attaches to (-) post.
https://www.amazon.com/Post-Battery-.../dp/B001N729FS
Old 01-08-2022, 11:41 AM   #3
farmertom
farmertom's Avatar
19Fordy did you mean attach to pos grnd post or the( -) post?
Old 01-08-2022, 11:44 AM   #4
farmertom
farmertom's Avatar
19Fordy did you mean attach to pos grnd post or the( -) post? I have 6volt pos grnd system.
Old 01-08-2022, 11:50 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
The disconnect should be on the ground side of the battery and if you have pos. ground then you will have to find a suitable switch.(bigger terminal)
If you are just disconnecting for the season then just remove the cable from the battery.
Old 01-08-2022, 11:56 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I use a heavy duty rotary switch mounted on the floorboard under drivers seat. See file attached below.
Fastronix Solutions 2 Post High Current Master Battery Disconnect Switch with Face Plate https://www.amazon.com/dp/B011EYWMDS...0878YQQKADW5PK
John
Old 01-08-2022, 12:43 PM   #7
petehoovie
petehoovie's Avatar
Old 01-08-2022, 12:53 PM   #8
50fordcoupeman
50fordcoupeman's Avatar
I use a knife blade type and yes on a 12v system it connects to the ground side of battery.
50fordcoupeman is offline   Reply With Quote
Old 01-08-2022, 02:03 PM   #9
slowforty
slowforty's Avatar
I prefer the knife blade type as it will not melt if you crank the engine for an extended period of time.
slowforty is offline   Reply With Quote
Old 01-08-2022, 02:38 PM   #10
19Fordy
19Fordy's Avatar
I meant to say that it is attached to the (+) battery terminal as shown in photo. Car is converted to 12V. If you look carefully at the photos you can see where I added a copper sleeve to the (-) terminal so that the OEM battery cable would fit. Very easy to make a sleeve. It's a Walmart battery.
Old 01-08-2022, 02:50 PM   #11
sugarmaker
sugarmaker's Avatar
For whats its worth I used the rotary in the floor on my truck project. Had never used one before. Probably a lot more bather to install one of these than one on the cable.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 01-08-2022, 08:19 PM   #12
paul2748
paul2748's Avatar
I just disconnect the ground cable
48 Ford Conv
56 Tbird
54 Ford Victoria
