Old 01-16-2022, 06:42 PM   #1
JSRTUDOR
JSRTUDOR's Avatar
Default Interior trim panels
Hi everyone, what are the interior panels made from in a 30 Town sedan? Specifically, what does the fabric attach to, card board, wood, or is the fabric just stretched and attached directly to the wood body structure? Thanks!
JSRTUDOR is offline   Reply With Quote
Old 01-16-2022, 09:57 PM   #2
Dick Carne
Dick Carne's Avatar
Default Re: Interior trim panels
Door panels and other related interior panels have a very heavy cardboard backing. In fact the term "cardboard" is somewhat misleading and perhaps a "press board" might be a better term. I'm not an upholsterer, and I am quite certain that there are many others infinitely more qualified to respond than I, but perhaps this may get you started on the right track. My understanding is that the only interior areas that would not have a cardboard backing would be perhaps the headliner. Hope this helps.
Dick Carne is offline   Reply With Quote
Old 01-17-2022, 06:04 AM   #3
Oldbluoval
Oldbluoval's Avatar
It’s called upholstery board and available in regular and “waterproof “…much different than cardboard
Or was available
Old 01-17-2022, 10:21 AM   #4
Ed in Maine
These panels are then nailed with 5/8 in. finishing nails (very small heads). Then the cloth is picked up with a needle to pull the cloth over the head of the nail. The nail head disappears and the panel is secured in place. Its like magic! Ed
Old 01-17-2022, 10:51 AM   #5
katy
katy's Avatar
Thanks
Old 01-17-2022, 11:27 AM   #6
rotorwrench
rotorwrench's Avatar
Chip board and panel board are other common names. A person needs a material that will not react badly to moisture. Pre-cut panel boards are available from some of the model A parts sources that handle upholstery materials.
The upholstery supply industry sell a number of these materials and also source others. Not all trimmers do the same quality of work but some come up with modern innovations that make sense. With panel board materials, a trimmer sometimes needs a material that they can sew to in some cases. Plywood and sheet metal don't work for this. Some even use fiberglass materials that they form themselves but that stuff isn't practical for antique cars.
Old 01-17-2022, 05:49 PM   #7
JSRTUDOR
JSRTUDOR's Avatar
Thanks!
Old 01-17-2022, 06:38 PM   #8
McMimmcs
McMimmcs's Avatar
Originally Posted by JSRTUDOR View Post
Thanks!
If waterproof is available, spend the extra money.
