06-25-2023, 12:49 PM | #1 |
Rear Main Oil Seals
What is the advantage of using a Graphtite rear seal over the one supplied in my Felpro gasket set. Does it provide a better seal-?
THANKS Mike |
06-25-2023, 02:21 PM | #2 |
Re: Rear Main Oil Seals
Both seal the same. Using the graphite the only advantage is there's less seal drag on the crankshaft compared to the rope version supplied in most gasket sets.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
06-25-2023, 02:35 PM | #3 |
Good for a couple of HP Ronnie :-)
Glenn |
06-25-2023, 07:29 PM | #4 |
Graphite will help with some gain. Were using lip seals now there definitely better for HP gains.
06-26-2023, 07:27 AM | #5 |
