04-08-2021, 07:39 AM | #1 |
Found my miss,,BUT
On my 46 3ton I tried a new coil as after points, carb, cond etc etc it would still do a 2300+ RPM miss ..Hit the bottom of your pants like a brick like twice a second. Point bounce was looked at too many times. Vac gauge was near perfect. I tested coil. It was low resistance than every source told me. So changed. Got rid of 70%. Adjusting idle screws near all out did 25 more%,although new coil tests same as old. Fuel starve?????
04-08-2021, 08:17 AM | #2 |
Re: Found my miss,,BUT
Idle mixture screws nearly all out?? Sounds like a Carb issue.
04-08-2021, 09:46 AM | #3 |
My,
Idle mixture screws maybe 1 turn out in MHO. Charlie ny |
04-08-2021, 12:16 PM | #4 |
Check that fuel pump is putting out.
It that looks good, check the float level setting in the carb. |
04-08-2021, 01:19 PM | #5 |
Good luck!
Ever stop to think and forget to start again? |
