Old 02-18-2021, 09:57 PM   #1
mgambuzza
mgambuzza's Avatar
Default Oil Leak Troubleshooting
Vacation week coming and I bought some parts to try addressing my oil leak on my 1930. I originally was going to replace the pan gasket, but the last time I ran it for about 10 minutes and let is sit overnight, I looked at both sides of the engine pan - drivers dry, passengers side wet. I then looked upward and saw where the oil return and valve cover a lot of seepage. I bought parts such as valve cover gasket, oil return gasket, bolts with copper washers, and a new oil return pipe (solder on original - possible former crack or leak). Never done this before on this type of car so although tight, can I remove the oil return and valve cover without removing the carburetor and intake/exhaust manifolds?
Hopefully this cares for the majority of the leaks. If not I'll have to wait for the next vacation for the oil pan. Pictures below.
mgambuzza is offline   Reply With Quote
