09-04-2010, 10:40 PM | #1 |
Dizzy adapter
Do I need an adapter to put a crab style distributor on a '38 flathead?
The only adapter I've seen is from Speedway but their catalog says it's for putting a '37 thru '41 dizzy on a '42 thru '48 engine. |
09-04-2010, 10:57 PM | #2 |
Re: Dizzy adapter
Yes, you do need an adapter. This is where I got mine. Good folks. Ed
http://www.thepitstopgary.com/pricelist.html Adapter/Spacer plate to use 2-bolt 21A (crab type) distributor on 32-41 engines$55.00 |
09-04-2010, 11:01 PM | #3 |
Re: Dizzy adapter
Yes, you will need an adapter to space out the 42 - 48 distributor if you are using the original '38 cam and this adapter also converts the three bolt timing gear cover to allow mounting of the two bolt distributor. See photo.
09-04-2010, 11:26 PM | #4 |
Re: Dizzy adapter
But I have the 2 bolt front cover also so I would just need the button adapter for the cam??
09-05-2010, 05:50 AM | #5 |
Re: Dizzy adapter
Not the "button" adaptor. Use the spacer plate as Ed Pitts described. When using the 2 bolt cover the cam "sticks out too far" (approx 7/16) so you need the spacer plate. Dick Spadora sells them also. Call him and he will answer all your questions before you order. John
09-05-2010, 06:33 AM | #6 |
Re: Dizzy adapter
As stated before Dick Spadaro carries the dist adapter, contact him for what you need . Good luck Bill |
