07-22-2010, 06:57 PM | #1 |
Model B transmission problem
The transmission was working fine. This morning I drove it around and then pulled it back into the driveway. I started the car and tried to move it and noticed that the shift pattern was skewed and had trouble finding the neutral gate. I pulled the lever down into the 1st gear position and found reverse. I'll pull the tower this weekend. What am I going to find? Bad forks, missing pieces?
07-22-2010, 07:11 PM | #2 |
Re: Model B transmission problem
It sounds like the end of the shift handle became mis-located in the slots in the shift forks. If nothing is actually broken, try removing the handle from the top (with the top still in place) and use a flashlight and a long screwdriver to get the forks back into alignment in nuteral. Re-install the shift handle and it should be just fine. Occasionally this happens when things get a little worn or you over run the shifter going into second.
BE CAREFUL when removing the shift handle NOT to DROP the pin that fits in the threaded part of the top. This pin keeps the shift handle from rotating and is easy to drop down into the trans. If you do drop it and can not fish it out with a magnet, try draining the oil and hopefully, it will come out. Good luck, let us know how you make out. Chris |
07-23-2010, 03:57 PM | #3 |
Chris,
This worked great, it is fixed. My question now is what caused it, or this just a common anomaly? |
07-23-2010, 06:10 PM | #4 |
I had the same thing happen to me twice with my B. I made an o/s pin that had a better fit in the slot of the shifter handle. I don't know if that fixed it or I was just lucky it did not happen again.
07-23-2010, 10:08 PM | #5 | |
This transmission does not have the best detent arrangement. Later top shift Ford Transmissions had better detents but even they can be shifted a little past the detent going into second gear. When I rebuild a early Ford transmission, I put in an internal stop to keep from over riding the second gear detent. The end of the handle, where it fits into the slots, may also be worn. If so, you can weld it up and re-shape it or find a better one. As previously posted, the pin in the top of the tower and the slot in the handle may also be worn. If this is tight, it may also help. It may not happen again but if it does, you will know how to fix it. GOOD JOB, Chris |
07-24-2010, 09:32 AM | #6 |
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
07-25-2010, 12:10 AM | #7 | |
