Old 03-23-2021, 01:19 PM   #1
PalAl
PalAl's Avatar
Default July/August 1991 "The Restorer"
If anyone has a copy of the July/August 1991 "The Restorer" magazine would it be possible for you to copy and send me the "TIPS" in the Tech Q & A column
dealing with shimming bearings?
Maybe if you can, copy and post them to this thread for others who may be interested in reading.
Thanks in advance.
PalAl is offline   Reply With Quote
Old 03-25-2021, 05:51 AM   #2
PalAl
PalAl's Avatar
Default Re: July/August 1991 "The Restorer"
Come on............... someone has a 1991 July/August "The Restorer" collecting dust on a shelf somewhere.
I could buy it from you.......
Old 03-25-2021, 08:15 AM   #3
TerryO
TerryO's Avatar
I should have that issue and I'll try to get it for you
TerryO is offline   Reply With Quote
Old 03-25-2021, 09:52 AM   #4
PalAl
PalAl's Avatar
Thank you Terry
Old 03-25-2021, 10:41 AM   #5
TerryO
TerryO's Avatar
Here ya go
Old 03-25-2021, 10:43 AM   #6
TerryO
TerryO's Avatar
I'm getting upload failure. I'll try later when I have more time.
Old 03-25-2021, 04:34 PM   #7
Bob Johnson
Bob Johnson's Avatar
MAFCA sells a thumb drive with the first 50 years of The Restorer. You might consider buying it so you can get any old articles.
Here is the Q&A you are looking for.
Bob Johnson
Q: A couple of months ago you spoke of setting rod and main bearings to 0.001" while using 0.005" shims. Is this possible? Claude Chambers Lone Jack, MO
A; No. Most of the rod and main shims you buy now for the model A are a sandwich of six or more identical 0.003", 0.004" or 0.005" shims stuck tightly together. With a sharp knife, you can peel away a shim at a time. Except where you are boring out new bearings with the shims in place, it is almost impossible to arrive at a 0.001" clearance when using shims this thick. For this reason, never throw away an old shim! With an assortment of shim thicknesses, a 0.001" clearance can generally be worked out.
Adjusting your rod and main bearing clearances isn't as difficult as it might seem. Here are a few tips:
(1) Determine approximately how much shim thickness is going to be required for proper bearing clear-
ance. Be sure that an equal thickness of shims is on each side of the bearing. Try not to cock the cap by using more shim thickness on one side than the other.
(2) Hopefully, you will have 10 or more thousandths of shims on each side of the bearing. If you have an assortment of 0.003", 0.004" and 0.005" shims, you can easily effect a 0.001" change.
(3) Keep all the bearing caps loose except the one you are adjusting.
(4) Although plastigage is a great help, it is not the final answer to proper bearing adjustment. Bearing "drag" is the best final criteria.
(5) Using the plastigage as a tool, adjust shims as necessary to obtain a 0.001"- 0.0015" bearing clearance. The clearance is seldom precisely the same across the entire bearing. It is unwise to go below 0.001" bearing clearance unless it represents an isolated "high spot" in the babbitt.
(6) Plastigage readings are not
dependable for clearances of less than 0.001". If the clearance is less than 0.001", plastigage can actually dent the babbitt. Try to guard against this.
(7) Check the torque required to turn the crank shaft after each adjustment. All caps should be loose except the one you are adjusting. The required torque should be "about" the same for each rod and slightly more for each main. With new rings, most of the torque will be to overcome ring drag. Loosen the cap after adjustment and go on to the next one. After all bearings have been adjusted, torque the nuts on each bearing cap. With all caps tight and using a crank or a torque wrench on the ratchet nut, the crank shaft should turn "hard" on a newly rebuilt engine and with some effort on a used engine.
Bob Johnson is offline   Reply With Quote
Old 03-25-2021, 06:26 PM   #8
McMimmcs
McMimmcs's Avatar
[QUOTE=Bob Johnson;2000220]MAFCA sells a thumb drive with the first 50 years of The Restorer. You might consider buying it so you can get any old articles.
Bob Johnson
(7) Check the torque required to turn the crank shaft after each adjustment. All caps should be loose except the one you are adjusting. The required torque should be "about" the same for each rod and slightly more for each main. With new rings, most of the torque will be to overcome ring drag. Loosen the cap after adjustment and go on to the next one. After all bearings have been adjusted, torque the nuts on each bearing cap. With all caps tight and using a crank or a torque wrench on the ratchet nut, the crank shaft should turn "hard" on a newly rebuilt engine and with some effort on a used engine.[/QUOT[/B]
That was indeed very kind of you! I’m sure you can expect a six pack in the mail ! Wayne
Old 03-25-2021, 09:12 PM   #9
TerryO
TerryO's Avatar
Looks like they have you covered...I still can't figure why I can't post pics.
TOB
Old 03-26-2021, 10:06 AM   #10
PalAl
PalAl's Avatar
TerryO, Bob Johnson & McMimmcs, thank you for taking the time to find and print out this article for me, it is much appreciated.
This help is what makes the "BARN" and the Model A Hobby so great.
Al
Old 03-27-2021, 01:28 AM   #11
CarlG
CarlG's Avatar
I'm still waiting for mine to come in the mail.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-27-2021, 05:29 AM   #12
mercman from oz
mercman from oz's Avatar
This is the cover of the magazine that you are chasing, and there is one for sale for $7.99. This is the Link:- https://jimsmegamagazines.com/the-re...y/p-31317.html
Old 03-27-2021, 10:23 PM   #13
PalAl
PalAl's Avatar
That made me laugh out loud.......... great sense of humor.
Much needed in these strange times
Thanks for the laugh
Old 03-27-2021, 10:58 PM   #14
McMimmcs
McMimmcs's Avatar
Your 1991 issue ?
