Old 05-22-2016, 09:57 PM   #1
Ingram 33vicky
Default Distributer timing fixture
Just came across what I was told is a fixture for setting the early Ford distributers.
Only thing I have to go on is the name CHEC RITE. If anyone has the instructions for this device I would like to get a copy. Sorry I am not adept at posting pictures.
Paul,
Ingram 33vicky is offline   Reply With Quote
Old 05-23-2016, 06:25 AM   #2
Hoop
Hoop's Avatar
Default Re: Distributer timing fixture
This question about instructions for vintage timing fixtures comes up frequently. Sometimes the instructions are available, other times not.
IF you understand early Ford distributors, you won't need instructions. The problem is that guys try to time a distributor without understanding what they want to do.
Bubba just got ahold of a KRW fixture and was looking for instructions. He's curious, I guess. The original KRW instructions are among the worst I've seen ... if Jim tries to figure them out, we won't be hearing from him for a while.
Any early Ford dual point distributor requires 3 basic adjustments:
1. The LH (as seated in the car) points need to be set as close to 22 1/2 degrees as possible. It's not that 22 1/2 is magical; this setting provides the proper range for the second adjustment.
2. Set the initial timing using the sliding index on the side of the case. A good timing fixture will locate 4 degrees (crank) advance for you. Most like the KRW do it automatically if you adjust the point break on the fixture to the proper mark.
3. Set the RH points to give a total dwell of 36.
Timing fixtures all display information that relates to the above. There will be a means to set the LH points. There will be a way to set the initial advance. There will be marks for total dwell with the RH points.
It's just another tool. I've never seen instructions for a screwdriver ... of course, if you don't know anything about screws, you might need some instructions.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 05-23-2016, 09:15 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Paul, here is an old post by someone looking for instructions for a Wasco timing fixture. Someone on this thread posted a pdf on instructions for this timing fixture, and bobH mentioned those instructions might be helpful on his Chec-Rite fixture. So maybe a quick pm message to bob and he may be of some help to you on what you are looking for... worth a try.
http://www.fordbarn.com/forum/showthread.php?t=67917
John
Old 05-23-2016, 09:49 AM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Actually i have owned two or three KW set up tools over the years but sometimes they get a little out of hand and pricey. I then sell them !!
The one i bought this weekend was a fair price and doesnt include the dwell attachment.
I use a dwell meter on a machine to set the dwell so the only function i actually have with this tool is the case timing to engine... Maybe i will find a dwell attachment??
Dwell is kinda interesting anyway as it is "a average of all eight cylinders" at rpm......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-23-2016, 09:53 AM   #5
BUBBAS IGNITION
Thats for the small individual dual points.
The large strap contacts set at 27 degrees on the LH.
The LH set controls case timing to engine.........
The RH set controls the dwell or coil build up....
[email protected]
