08-03-2023, 06:34 AM | #1 |
ID of Water Take-off please
A special early V8 flathead has pump-less water take-offs.
Can anyone here identify them, please? |
08-03-2023, 07:27 AM | #2 |
Re: ID of Water Take-off please
How about a pic showing the entire engine?
08-03-2023, 07:56 AM | #3 |
I think that showing the whole thing will raise more questions and detract from my original enquiry. I just want to know where the water take-offs came from and whether a pair may be available somewhere.
But since you've asked, here goes : The car was built in 1935 in England to race at Brooklands Motor Course. Development of the engine included Federal Mogul argentiferous copper high compression heads and eight AMAL motor cycle carburettors, down draught. The 1932 Ford V8 chassis was shortened and underslung at the rear where the track was reduced. A Lincoln gearbox was used with a shortened torque tube. The steering was geared up with a longer Pitman arm for 1½ turns lock-to-lock. Now, what about those water take-offs? Last edited by Biggles; 08-03-2023 at 11:31 AM. |
08-03-2023, 03:25 PM | #4 |
Can’t help, but will say Wow! Would love to hear it run.
I dig coal, which provides motivation for EVs. |
08-03-2023, 03:45 PM | #5 |
Regret I cannot let you hear that - photo was taken in 1938. I'm re-creating that engine.
However, I can let you hear the engine that's in the car now - 305ci blown flathead. The fastest flathead on Pendine Sands - standing start half mile to 117 mph. https://youtu.be/pMaup4QUPaw |
08-03-2023, 04:02 PM | #6 |
08-03-2023, 06:55 PM | #7 |
A steel welded up [fabricated], or aluminum, version would work. Newc
08-04-2023, 10:18 AM | #8 |
Watch some of the videos of Michael Waller (Brittania Motorcycles) or Allen Millyard (both from the UK). They both do some amazing fabrication work on motorcycles. A Casting might be the obvious solution, but a welded/fabricated piece would work as well.
Al Hook |
08-04-2023, 11:15 AM | #9 |
You might also look for a metal sculpture student who does aluminum castings. My brother taught sculpture for years and he and some of his students did that sort of thing. For a commission, of course. He actually came to the UK a few times to do seminars/work with a fellow in Wales named Harvey Hood. Not sure what school he was affiliated with. Google might know. My brother's name was Charles Hook, taught at Florida State U for years.
Al Hook |
08-04-2023, 11:33 AM | #10 | |
08-04-2023, 08:31 PM | #11 |
I'm going to guess the water outlets on the originally pictured engine were special made. I have not seen anything like them before. Your best bet is probably to make a set yourself, either assembled and welded out of aluminum or cast.
08-05-2023, 04:10 AM | #12 | |
Thanks to all who replied with constructive suggestions - greatly appreciated. |
