Old 10-27-2022, 02:22 PM   #1
snappydon
snappydon's Avatar
Default Mystery ‘37 85hp engine bolts…help
So as I’m organizing my parts and pieces for my 1-1/2 ton, I have these 2 bolts (actually 4 but I have mixed parts from 2 engines) that I can’t figure out where they go.
Any input is really appreciated. I don’t want to put something together and tear it apart again.
I’ve had the timing cover and pan off to replace the soft plugs in the pan rail. I suspect they go there somewhere?
File Type: jpg 1C7EC77C-C40B-4E3A-A6C9-5D28F2FC504B.jpg (68.0 KB, 107 views)
snappydon is offline   Reply With Quote
Old 10-27-2022, 02:39 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Mystery ‘37 85hp engine bolts…help
Stepped shank bolts like that are special bolts for sure. I've seen similar bolts for hinge applications. Maybe a 37 Ford owner can nail them down for you. Most flathead V8 engines use same or similar bolts no matter the year and I certainly can't recall engine bolts like that.
Old 10-27-2022, 02:52 PM   #3
snappydon
snappydon's Avatar
I'm not even sure now that they're from the '37.
This project got stacked into a pile and moved to the side of my shop, I'm really frustrated trying to sort and identify things.
Gotta love helpful family.
Old 10-27-2022, 03:02 PM   #4
Lawson Cox
Lawson Cox's Avatar
"I'm not even sure now that they're from the '37.
"This project got stacked into a pile and moved to the side of my shop, I'm really frustrated trying to sort and identify things."
Try putting a 35 peecup together, that never was together. My truck is assembled from parts gathered from all over the country, even a couple of parts from NZ.
No parts from the same vehicle except for maybe running boards.
Old 10-27-2022, 07:34 PM   #5
v8fordman
v8fordman's Avatar
They are definitely not from a flathead engine. They look similar to the bolts that allow the top to pivot on my ‘37 convertible sedan, but those had a slotted screw head not a hex. Therefore, you have a mystery bolt(s).
v8fordman is offline   Reply With Quote
Old 10-28-2022, 03:53 AM   #6
Ideucev8
They look like 32 Roadster trunk lid hinge pivot bolts.
Ideucev8 is offline   Reply With Quote
Old 10-28-2022, 10:35 AM   #7
Karl Wescott
Karl Wescott's Avatar
Agree. 5/16 pin + 3/8 thread + 1/2 hex head is most likely the trunk pivot bolt. 1928-32 5 Window and roadster.
Karl Wescott is offline   Reply With Quote
