09-04-2020, 09:24 AM | #1 |
24 Stud Motor with Casting Number C 254 11 ??
Does anyone know what year/displacement this motor is? I bought it from a fellow that had it in a 1940 Ford and it is in good running condition. I had planned on using it in my 41 convertible as is so was not going to open it up unless I had to. It has 38 heads on it, but that doesn't mean anything. Thanks for any info.
Chuck |
09-04-2020, 11:21 AM | #2 | |
Re: 24 Stud Motor with Casting Number C 254 11 ??
Phil NZ |
09-04-2020, 04:07 PM | #3 |
Thanks Phil.
Chuck |
09-04-2020, 04:30 PM | #4 |
Doesn't the C stand for commercial or Canadian????
My Guess is commercial like generator ,farm irrigation pump ,welder. |
09-04-2020, 06:44 PM | #5 |
Hey Chuck...Out of all the wonderful info that Mac VanP has compiled for the world on his great site, you're not likely to find the number " C 254 11 " hidden amongst any of it. Many similarly-styled numbers are lost as to their original meanings, but obviously played some part in the original casting and block-mold process. If you could even give us an idea of where that number is found on the block, it MAY (or may NOT) help determine whether that "C" MIGHT mean "Canadian" origin, or "Commercial" application, or just superfluous information. Better clues would include number of head studs, distributor type, rear bellhousing configuration, oil fill/breather location, raised or flat intake manifold surface, numbers cast into the heads, fan configuration, and certainly a picture or three. DD |
09-05-2020, 10:10 AM | #6 |
This was our best ID thread back when all the pictures were still there. Photobucket stuff got dropped but it still has a lot of information. https://www.fordbarn.com/forum/showt...5301&showall=1 |
