Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 07-02-2010, 01:40 PM   #1
rodomotive
Default WANTED:16"x5" MERC/LINCOLN wheels
City: Vancouver
State: WA or B.C.
Need a pair of 16" x 5" steel wheels with 5 on 5 1/2" bolt pattern and internal nubs or clips for inside mount hub caps. I believe these wheels were from 1941 Mercury and Lincoln.
Thanks, Jeff
rodomotive is offline   Reply With Quote
Old 07-03-2010, 02:53 PM   #2
hotrod
Default Re: WANTED:16"x5" MERC/LINCOLN wheels
I have a set of 15" x 5-1/2" wheels with the 5-1/2" bolt patteren and nubs on the inside for hubcaps. These are original ford wheels that i had on my 1946 ford coupe. used the original 1946 hubcaps on them. I'd want $200 for the set of 4 wheels plus shipping. They are in very nice shape. I ran radial tires on them tubless.
Larry
hotrod is offline   Reply With Quote
Old 07-03-2010, 02:53 PM   #3
hotrod
my e-mail is [email protected]
Old 07-03-2010, 05:52 PM   #4
26 lakes
Jeff, I have one wheel. Here are some pictures of it. I want $50.00 plus shipping for it. Thanks, David Atkins
26 lakes is offline   Reply With Quote
Old 07-08-2010, 11:47 AM   #5
rodomotive
Bttt
Old 07-13-2010, 05:41 PM   #6
rodomotive
Bttt
Old 07-16-2010, 03:26 PM   #7
rumblegutz
rumblegutz's Avatar
I have a Lincoln 16x5 with 5.5 bolt pattern and the wheel is even in Canada. Although at the over side of the country. The wheel has the clips for a hub cap and they are in good shape. I believe the wheel should clean up pretty good. Beads are not heavily pitted from rust.
rumblegutz is offline   Reply With Quote
Old 07-25-2010, 11:10 AM   #8
rodomotive
Bttt
Old 07-30-2010, 01:15 PM   #9
rodomotive
Bttt
Old 07-30-2010, 05:38 PM   #10
timcharles
timcharles's Avatar
Would the ford f-1 wheels work for you. They're 16 x 5 or 5 1/2 with nubs on the
inside. I can't tell the actual width because they have worn out tires on them.
timcharles is offline   Reply With Quote
