Old 09-04-2023, 07:41 AM   #1
47topless
47topless's Avatar
Default Flywheel inspection possible?
I suspect that I have a bad ring gear that is jamming up my starter. Is there any way to inspect the flywheel with the engine in the car, or am I destined to pull the engine to take a look at the ring gear?
Thank you,
Phil
47topless is offline   Reply With Quote
Old 09-04-2023, 08:09 AM   #2
deuce5wndw
deuce5wndw's Avatar
Default Re: Flywheel inspection possible?
You should be able to inspect it through the hole after the starter is removed. Turn the engine with a socket on the crankshaft pulley.
deuce5wndw is offline   Reply With Quote
Old 09-04-2023, 08:17 AM   #3
KiWinUS
KiWinUS's Avatar
You would need a mirror as the wear on ring gear is on backside of ring gear.
Old 09-04-2023, 09:30 AM   #4
KiWinUS
KiWinUS's Avatar
Sorry double post
Old 09-04-2023, 10:13 AM   #5
J Franklin
J Franklin's Avatar
When the starter is out you can inspect the drive and shaft for any damage or bends.
Old 09-04-2023, 07:06 PM   #6
47topless
47topless's Avatar
Starter looks fine. It is new.
Rocking the car in 3rd gear unlocks the starter, so I suspect a bad ring gear.
Oh well.
Thank you all for the good suggestions.
Phil
Old 09-04-2023, 07:08 PM   #7
Don T
Don T's Avatar
This is just FYI for starter jamming problems, not necessarily related to 47 topless's problem. I have replaced the ring gear on 2 8BA's, both running driving vehicles and have had both of them jamb. I have changed my starting technique from just touching the starter with no throttle to giving just a bit of gas (to make sure I get a sure start to kick the starter out) and staying on the starter button just a millisecond longer to complete the start. When I had one of the engines out (long sad story as to why) I took a serious look at the replacement ring gear; like most stuff we get for these old vehicles it was what I would call "rough" machined. The Bendix used on this engine was in excellent shape, no reason to rebuild or replace it. I spent a bit of time with a dremel to "ease" the edges of the ring gear teeth, hoping for a smoother entry/exit of the starter gear into the ring gear. I have put about 6K miles on this car since doing this without a stuck starter event, even when I get sloppy with my starting technique. Just a thought for others who are doing or did a ring gear replacement.
Don T is offline   Reply With Quote
Old 09-04-2023, 07:20 PM   #8
alanwoodieman
does your starter have the bracket that bolts to the oil pan rail?
alanwoodieman is offline   Reply With Quote
Old 09-04-2023, 09:05 PM   #9
deuce5wndw
deuce5wndw's Avatar
That is a great question I didn't think of!
Old 09-04-2023, 10:03 PM   #10
Pete
Pete's Avatar
Oh well.
Phil
One jam job can bend the shaft. The starter is junk then till it is fixed.
Exam of the flywheel is done with a small mirror as suggested previously.
Old 09-05-2023, 05:47 AM   #11
KiWinUS
KiWinUS's Avatar
Remember it Will possibly only have wear in 4 spots. As you look with your mirror you need to slowly turn engine.
Old 09-05-2023, 07:16 AM   #12
47topless
47topless's Avatar
yes.
