Old 01-18-2013, 01:57 AM   #1
52merc
52merc's Avatar
Default offenhauser twin carb inlet
a friend has one of these and just discovered that the geanerator slot is off set,any reason for this,, thanks
52merc is offline   Reply With Quote
Old 01-18-2013, 02:03 AM   #2
ford38v8
ford38v8's Avatar
Default Re: offenhauser twin carb inlet
The front carburetor would otherwise interfere with the generator.
Alan
Old 01-18-2013, 02:40 AM   #3
my4dv8
In a 8ba motor this puts the fan and generator offset which looks weird in a hot rod with no hood, and puts offset loads on pulleys. the fan is 1 1/4" off to the left .Is there a way to correct this off set ? A powergen generator is shorter than an original ( think) so clearance may not be an issue.
my4dv8 is offline   Reply With Quote
Old 01-18-2013, 07:40 AM   #4
oldskool
oldskool's Avatar
I also have an offy dual carb manifold that I planned on using on my 8ba powered 41 ford and I don't like that offset,i also have an edelbrock 4 bbl intake and it mounts the gen in stock location,im leaning on the edelbrock as I might want to use a fan shroud,and the offy would be a problem with its offset...
oldskool is offline   Reply With Quote
Old 01-18-2013, 08:16 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Mine is a 4bbl. Offy and it is offset to the passenger side by 7/8"
(not 1 1/4" )
And yes there is a way to correct it.
In my case I fabricated a new fan/pully mount.
This is the new mount.
Old 01-18-2013, 08:26 AM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
(not 1 1/4" )
Nice job on the offset. I have an Offy 4bbl intake on an 8BA I've just about all done. it's on one of my engine stands. I'll have to check and see if it's offset. Walt
Old 01-18-2013, 08:38 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
If it's offset there is no reason to correct it unless there are interference
problems. In my case I have a fan shroud which the fan hit.
Old 01-18-2013, 01:18 PM   #8
my4dv8
This is a regular twin so perhaps the off set is different.
Did you just cut off the original fan bracket base and re weld it further over?
Are these cast or forged? How would the welding heat affect the fan hub?
Thanks.
(not 1 1/4" )
Old 01-18-2013, 02:30 PM   #9
Ol' Ron
Ol' Ron's Avatar
I have an Offy 4bl intake for an 8BA and it's not offset.
Old 01-18-2013, 02:43 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
Thanks.
The intake manifold was not altered. I just fabricated a new fan/pulley mount out of 3/4" flat stock and a short piece of round stock plus mat. for gussets. This provided a welded platform to drill a hole for the original pulley shaft to be pressed into. This only moves the fan/pulley to where it belongs. The alt. is mounted in its original location.
Old 01-18-2013, 02:49 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
Would like to see a pic of it. Sounds to me like it may be an early production model. After looking at many over the years I have never seen one that is not offset.
