Old 01-09-2021, 05:54 PM   #1
Ed in Maine
Default Reducing Steering Free Play
I have completed the steps to reduce free play in the steering box and I am confident that the steering box is not a factor. The movement at the circumference of the wheel is about 1 1/4 in. What can be done to reduce lost motion in the drag link and tie rod? The problem is the car lurches back in forth in stiff wind and with pavement irregularities. It is not comfortable to drive when doing 45-50 mph. Any suggestions? Thank you, Ed
Old 01-09-2021, 06:19 PM   #2
TMarsh
Default Re: Reducing Steering Free Play
Radial tires helped mine but the wind will always be a factor on these boxes
TMarsh is offline   Reply With Quote
Old 01-09-2021, 06:41 PM   #3
700rpm
700rpm's Avatar
Is it a 7 tooth or a 2 tooth?
Ray Horton, Portland, OR
Old 01-09-2021, 06:43 PM   #4
GRutter
GRutter's Avatar
Ed
Movement of that magnitude should be fairly easy to spot. Top to bottom, the kingpin bushings would be suspect and/or wheel bearings.
If you eliminated the steering box as a source of free play, then with the steering wheel held straight ahead, there should be NO movement of the pitman arm when you are grabbing the circumference of the wheels and moving left & right, but you should be able to identify any other source of play.
GRutter is offline   Reply With Quote
Old 01-09-2021, 07:17 PM   #5
Jacksonlll
Jacksonlll's Avatar
Set your toe in.
Old 01-09-2021, 07:30 PM   #6
Mulletwagon
Mulletwagon's Avatar
Might also ensure the Pittman arm is solidly clamped to the sector shaft. Look at the connection closely while rocking the steering wheel. Even a minute amount of looseness will result in significant play.
Mulletwagon is offline   Reply With Quote
Old 01-09-2021, 09:48 PM   #7
Big hammer
Check and make sure the gear box is tight to the chassis frame.
get a bigger hammer tap done
Old 01-10-2021, 08:43 AM   #8
old31
I am guessing you did the adjustments correctly.
Toe-in and radials will help a lot with your issues.
old31 is offline   Reply With Quote
Old 01-10-2021, 10:56 AM   #9
Purdy Swoft
Purdy Swoft's Avatar
Set the toe-in at one sixteenth .
Old 01-10-2021, 11:04 AM   #10
1930artdeco
1930artdeco's Avatar
Here are my thoughts and what I have done:
1) Replace steering balls to get rid of the 'death wobble'
2) Adjust steering box outside of car
3) Adjust toe-in to spec
4) When I reconnected the pitman arm I snugged it up an extra turn or so and that took out a lot of play. I also have the Teflon cups in mine.
5) Check king pins
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-10-2021, 06:45 PM   #11
duke36
The steering box freeplay with new box components can get very close to 1/4 " at the wheel at the center position, equal lash at both extremes and with wood ruff key pointing towards fill hole, etc. Once that's OK, then the other steps + front wheel bearing adjustment with very slight amount of preload (see other threads). A shortened pitman arm usually requires an adjustable drag link to get the gears centered with wheels straight ahead..
Old 01-11-2021, 02:02 AM   #12
RHD
RHD's Avatar
If your car is fitted with a 7 tooth sector, the answer to near zero freeplay is in my book titled 'The Complete Model A Ford Restoration Manual. All other freeplay in balljoints etc must of course be eliminated and you will be guaranteed excellent steering. Available from Mike's Affordable.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 01-11-2021, 08:29 AM   #13
Patrick L.
Patrick L.'s Avatar
Is that 1.25" free-play in just the box or total ? If total thats not too bad. If just the box, it should be better/less.
I agree with properly setting the toe.
Old 01-11-2021, 11:57 PM   #14
GRutter
GRutter's Avatar
Quote "Is that 1.25" free-play in just the box or total ? If total thats not too bad. If just the box, it should be better/less."
I am soooo confused. We are talking about OP's steering and vehicle control.
Why would anyone advise that 1 1/4" of free-play is OK ?
If the play is not in the steering box, then it's in bearings, tie-rod ends, drag-link ends, or loose pitman arm. In which of those components would anyone think that 1 1/4" play is OK... even if cumulative?
And until free play is eliminated, why are we advising to set toe-in or buy radial tires.
Old 01-12-2021, 02:37 AM   #15
Bill G
Bill G's Avatar
Well said. Excellent points.
Old 01-12-2021, 05:38 AM   #16
Bruce of MN
Bruce of MN's Avatar
Make sure where the radius rods connect is no-slop.
Old 01-12-2021, 08:01 AM   #17
CountrySquire55
CountrySquire55's Avatar
I had a similar problem that was greatly improved by tightening the pittman arm on the sector shaft (it took some muscle) and setting the correct toe-in. My 1931 Town Sedan now steers very nicely with only a tiny bit of free play but no wandering.
CountrySquire55 is offline   Reply With Quote
Old 01-12-2021, 09:37 AM   #18
Patrick L.
Patrick L.'s Avatar
If there is 1.25" of free-play at the steering wheel, then thats not too bad. Less than an inch is good, but, an extra .25" isn't too bad.
By now I would think everyone here would know that free-play is cumulative and all the components should be checked/adjusted/fixed.
Old 01-12-2021, 01:39 PM   #19
GeneBob
Sounds like I need to start looking at my steering linkage. I have been wondering what normal is for a Model A. My steering wheel will turn about twice as much as Ed's before moving the car's lane position when cruising in a straight line. I just figured 2 1/2" at the rim is what people accepted in 1930.
GeneBob is offline   Reply With Quote
Old 01-12-2021, 03:16 PM   #20
Patrick L.
Patrick L.'s Avatar
To check steering wheel free-play while vehicle is stopped just lightly turn wheel in one direction until resistance is felt and consider it as zero. Then turn in opposite direction lightly until slight resistance is felt. Measure that distance.
