Old 12-25-2020, 04:35 PM   #1
Oldgearz
Default Spark plug socket
Can't seem to find a 15/16" spark pug socket for 3/3" drive. Any ideas?
Oldgearz is offline   Reply With Quote
Old 12-25-2020, 04:45 PM   #2
Oldgearz
Default Re: Spark plug socket
That was supposed to be 3/8" drive.
Old 12-25-2020, 05:00 PM   #3
shew01
shew01's Avatar
I don’t recall... Is the spark plug a 13/16” instead of 15/16”?
shew01 is online now   Reply With Quote
Old 12-25-2020, 05:27 PM   #4
J Franklin
J Franklin's Avatar
Maybe just use the spark plug wrench Ford provided, they do work.
Old 12-25-2020, 05:28 PM   #5
Ruth
I use a 15/16" deep socket, ⅜" drive similar to these. https://www.ebay.com/itm/A-CRAFTSMAN...AAAOSwzsNcfqD3
Or use a ⅜" to ½" adapter on a ½" drive socket.
Ruth
Old 12-25-2020, 05:59 PM   #6
Oldgearz
Thanks Ruth. I would like to have the rubber insert but guess I can just use any deep socket. I want to weld a 3" extension on it, but was hoping someone sold something like that already made up. I'm not much of a welder as mama never taught me that.
Old 12-25-2020, 06:04 PM   #7
Synchro909
Synchro909's Avatar
I prefer a 15/16 ring spanner (or 24 mm). Less chance of it slipping sideways and cracking the insulation. Just be careful to not over tighten.
Old 12-25-2020, 06:17 PM   #8
Ruth
Is a ring spanner the same as a box end wrench?
Ruth
Old 12-25-2020, 08:51 PM   #9
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I use an adjustable wrench on my 3X plugs. One time, it slipped off and hit the adjacent plug, cracking it. I still use the adjustable wrench, but am very careful. At that time, 3X’s were about $25 apiece.
Old 12-26-2020, 08:21 AM   #10
Patrick L.
Patrick L.'s Avatar
Box wrench just to crack loose and snug up. A little never-seize lets them spin right out and back in.
A chunk of rubber tube inside the socket should keep from breaking them.
Old 12-26-2020, 09:34 AM   #11
Badpuppy
The first time I heard the term "spanner" was in a NATO motor pool 50+ years ago. The bloke was holding one in his hand, so I caught on right away what he meant. I suspect "wrench" was just as alien to his ear. -- And a "box" has square corners.
These days we must all be multilingual.
Old 12-26-2020, 10:00 AM   #12
nkaminar
nkaminar's Avatar
Don't some Model A spark plugs tank a different size wrench?
Old 12-26-2020, 10:40 AM   #13
rocket1
yes they sell reducers so you can use modern plugs and some older plugs that are subtitutes foe 3x are a smaller size.
rocket1 is offline   Reply With Quote
Old 12-26-2020, 12:05 PM   #14
Ruth
Yes but he specifically asked about a 15/16" socket, which fits the W-16Y and W-18 Champion. I believe the 3X uses a 1⅛" socket. I don't have one handy to measure.
Ruth
Old 12-26-2020, 02:19 PM   #15
1931 flamingo
1931 flamingo's Avatar
NAPA, AutoZone , etc should have one. Use a 3/8;s extension.
Paul in CT
Old 12-26-2020, 03:15 PM   #16
shew01
shew01's Avatar
After I got home, I found I’m using g a Tekton 15/16” spark plug socket. It looks like Home Depot carries them.
https://www.google.com/shopping/prod...:1,prmr:1,cs:1
Old 12-26-2020, 04:27 PM   #17
Synchro909
Synchro909's Avatar
Yes, that is a ring spanner. In English, a wrench is defined as a sudden violent twist or pull. It can be used in a sentence this way: "with a wrench Tony wriggled free"
So, a wrench is the action applied to a spanner, not the spanner itself.
It seems to me that this is just one more example of how you guys "developed" your own language when Webster dumbed down the language.
Last edited by Synchro909; 12-26-2020 at 07:59 PM. Reason: Correct a typo by putting the "r" in wrench.
Old 12-26-2020, 05:28 PM   #18
CarlG
CarlG's Avatar
... In English, a wench is defined ...
When I look it up, this is what I find:
Wench. A 13th-century word meaning a female infant or a young unmarried woman quickly acquired negative connotations: from the late 14th century, in Langland and Chaucer it is used to mean “a wanton woman; a mistress”.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-26-2020, 06:15 PM   #19
Ruth
Haha, Good one Carl.
Ruth
Old 12-26-2020, 07:58 PM   #20
Synchro909
Synchro909's Avatar
That is probably a reasonable description of our Model As but not what I meant. Obviously, I made a typo by missing the "r". Oooops!
