Old 07-07-2020, 01:31 PM   #1
Dennisfly
Dennisfly's Avatar
Default King Pin Retaining Bolts
My king pin retaining pins/bolts have been installed backwards. They were inserted from the rear of the axle and the nut/steering stop is on the front. I became aware of this when the inside of my left front tire rubbed on the brake rod during a tight turn. I figured I could just remove them and reinstall in the proper direction. I removed the nut and lock washer, reinstalled the nut loosely with some space under it and tried to drive the pin out. No luck. I’m using a 24 oz hammer with a long drift rod. I’ve tried with weight on and off the wheels. There is no rust visible, the king pins have no play, and I believe these were rebuilt within the last several years.
Should I go with a five pound sledge or is there something else here that I’m unaware of?
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 07-07-2020, 01:46 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: King Pin Retaining Bolts
I had to drive mine out with a sledge and even then it took some beating. Could apply some heat too but the sledge should definitely work.
Old 07-07-2020, 02:15 PM   #3
MAG
MAG's Avatar
"I became aware of this when the inside of my left front tire rubbed on the brake rod during a tight turn." Firestone tires?
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 07-07-2020, 02:49 PM   #4
mrraford
The holes through the axle are tapered so you could conceivably be trying to drive the bolts against the taper.
I have had the opportunity to make the mistake of installing the axle backwards and therefore try to install against the taper. A lesson in humility.
mrraford is offline   Reply With Quote
Old 07-07-2020, 02:57 PM   #5
Bill G
Bill G's Avatar
Even with normal installation, I have had to hammer on them to get them out. Be sure to put the domed nut on the bolt a good distance and beat on the domed nut so you don't screw up the threads on the bolt.
Old 07-07-2020, 03:28 PM   #6
Marshall V. Daut
Check your private messages in the upper right corner of this webpage.
Marshall
Marshall V. Daut is online now   Reply With Quote
Old 07-07-2020, 03:29 PM   #7
Jacksonlll
Jacksonlll's Avatar
If they fit ok before and they won’t now, your axle is backwards. Easier to just leave it the way it was unless you are up to the job.
Old 07-07-2020, 05:30 PM   #8
David R.
The holes in my AA axle aren’t tapered but the pins are. They wedge against the flat on the king pin. I measured the holes with an inside caliper because I thought they would be tapered but they aren’t.
David R. is offline   Reply With Quote
Old 07-07-2020, 05:33 PM   #9
daren007
I’m going with David. The axle does not care.
daren007 is offline   Reply With Quote
Old 07-07-2020, 07:23 PM   #10
Dennisfly
Dennisfly's Avatar
I do have Firestone tires, but I'm thinking that if the turn stop nuts were on the back side of the axle as they should be, this wouldn't have happened.
1935 Model 48 Tudor
Old 07-07-2020, 07:26 PM   #11
Dennisfly
Dennisfly's Avatar
I thought I read somewhere that the axle could properly be installed either way, but I certainly could be wrong.
1935 Model 48 Tudor
Old 07-07-2020, 07:27 PM   #12
Synchro909
Synchro909's Avatar
I've always found the cotter pins could go in from either side.
I STRONGLY advise against any hammering to get them in. The result of doing that is the king pin eye in the end of the axle gets stretched and the stub axle behaves just like the bushes are flogged out. I am about to take my Brother in Law's front axle to have this repaired after a previous owner drove the cotters in too far. Once that is done, I'm sure we will be able to remove the steering stabilizer they put on there to cover the problem.
Old 07-07-2020, 09:47 PM   #13
chrs1961815
chrs1961815's Avatar
Also, be extremely careful when tightening those nuts. I broke one recently by going a little too far with a socket. Learned my lesson - use a wrench instead and take it easy.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-08-2020, 06:55 AM   #14
old31
Chris, what did you do for a repair. Ouch!
old31 is offline   Reply With Quote
Old 07-08-2020, 07:26 AM   #15
chrs1961815
I just drove the pin back out and got another one.
Old 07-08-2020, 10:49 AM   #16
katy
katy's Avatar
I would try: put the nut(s) back on loose, install the cotter pins, go for a drive, then try removing the pins. May or may not work, but it's worth a try.
Old 07-08-2020, 06:40 PM   #17
daren007
Once again, The axle does not care.
Old 07-08-2020, 07:28 PM   #18
Dennisfly
Dennisfly's Avatar
There are no Cotter pins. There is a lock washer and a special nut/steering stop.
1935 Model 48 Tudor
Old 07-08-2020, 07:45 PM   #19
John
John's Avatar
Sometimes a hand held pneumatic hammer will "rattle" items loose that otherwise seemed to be joined together for good. Add a bit of your own penetrating oil to the joint for luck.
John
John is offline   Reply With Quote
Old 07-08-2020, 10:28 PM   #20
Synchro909
Synchro909's Avatar
That is a cotter pin on the left.
