Old 07-30-2019, 12:28 PM   #1
1929
Default Oil pan bolts
It would take me 30 minutes to take out the two front oil pan bolts because of a tight fit between pan and crossmember, so I grind down this socket, and it made it as simple as removing the others.
1929 is offline   Reply With Quote
Old 07-30-2019, 01:16 PM   #2
Dick So. Cal.
Default Re: Oil pan bolts
I cut a slot in them with a hacksaw and remove them with a screwdriver. Works great!
Dick
Dick So. Cal. is offline   Reply With Quote
Old 07-30-2019, 01:19 PM   #3
noyo55
Back in 66 or so I had an older fellow come up to me ,when I was sitting in my model A, and asked if I had problems getting the pan bolts out. When I said yeas he said that he had a special speed wrench made for taking them out. He said come by and get it, I did and it works great —I keep it under the seat. The wrench’s are probably out there.
noyo55 is offline   Reply With Quote
Old 07-30-2019, 01:21 PM   #4
Benson
Benson's Avatar
weds morning 5 am
Benson is offline   Reply With Quote
Old 07-30-2019, 02:38 PM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
What torque do you guys use. The book says 20 FT lbs, but the bolts are never dry. I put 20 on mine and they are really tight but did not break. That's probably too much.
Jacksonlll is offline   Reply With Quote
Old 07-30-2019, 02:59 PM   #6
mfarley
mfarley's Avatar
I've heard that's a misprint and that 20 in-lbs more like it.
mfarley is offline   Reply With Quote
Old 07-30-2019, 03:04 PM   #7
WTSHNN
WTSHNN's Avatar
Tighten them up until the gasket just begins to mushroom out.
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 07-30-2019, 03:23 PM   #8
ryanheacox
ryanheacox's Avatar
When I did mine I used the same spec as the valve cover gasket on my Jeep, 7 ft-lb.
ryanheacox is offline   Reply With Quote
Old 07-30-2019, 07:19 PM   #9
Synchro909
Synchro909's Avatar
I do as Dick in So Cal does (post #2). Mine are drivers cars, not show cars so I don't care - not that anybody will ever see the slots. I do the same with the bolts right at the back of the sump too.
When I come accross a car with bolts in the front of the sump, I jack the front off the ground under the axle so I can easily turn the steering to a position where I can get at them. (I do the same when greasing the steering ball joints.)
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-30-2019, 10:12 PM   #10
chrs1961815
chrs1961815's Avatar
Depends on the gasket. I think it is pretty much only necessary to snug them nicely with a hand rachet then after a few drives retighten. It is not like a head gasket where there is compression as well; this gasket is just holding back oil so torqueing the hell out of it is not going to help, it probably will hurt if you are using a cork gasket.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-30-2019, 11:21 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Do you have a picture of your tool you could share? I love special use tools.
Old 08-02-2019, 10:51 AM   #12
Jim Brierley
I just use a wobble-socket.
Jim Brierley is offline   Reply With Quote
Old 08-02-2019, 02:15 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Same with me.
I use a 1/4" socket set with no problems.
Old 08-02-2019, 02:26 PM   #14
abachman3
abachman3's Avatar
I too, use the 1/4 inch socket. For all the tighter it needs to be, the 1/4 inch is plenty.
abachman3 is offline   Reply With Quote
Old 08-02-2019, 10:26 PM   #15
Mike V. Florida
Mike V. Florida's Avatar
Yes it is a mis-print! 3-5 lbs. is all that is needed.
