Old 08-06-2016, 02:41 PM   #1
u.cremer
Default Volt
Hello, I have another question.
I have a 28 'Ford A with 6Volt system, all original.
In the state of running the generator but wavering about 9.8 to 10.8 volts.
It will burn out all the bulbs.
How much is ok?
Sorry please, translator
u.cremer is offline   Reply With Quote
Old 08-06-2016, 02:47 PM   #2
wmws
Default Re: Volt
6.6 Volts is all you should have with a 6 volt system. Much more than that will blow out bulbs. Where are you measuring the 9.8 to 10.8 volts?
wmws is offline   Reply With Quote
Old 08-06-2016, 03:06 PM   #3
Bob C
Default Re: Volt
You also need to use an analog meter to get a good reading.
Bob
Old 08-06-2016, 03:23 PM   #4
u.cremer
Default Re: Volt
Hi,
Its a Digital Multimeter, and i remeasure after the relay
I hope it is translated correctly
Old 08-06-2016, 03:27 PM   #5
marc hildebrant
marc hildebrant's Avatar
Default Re: Volt
Try using an "analog" meter or one with a pointer and scale. The digital meters can be sensitive to rf noise on the generator output and give an incorrect answer.
The analog meters work better because the mechanical pointer "damps" the noise out from the DC reading.
Marc
marc hildebrant is offline   Reply With Quote
Old 08-06-2016, 03:56 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Volt
Here you go. Every Model A owner should have at least a basic analog DC volt meter, and they don't come much cheaper than this. If you have a bad connection in the charging circuit, or if the battery is too weak or small, then the generator will put out too high a voltage, unless you use an electronic voltage regulator, as I do.
http://www.ebay.com/itm/1pcs-New-DC-...MAAOxy2BBSUjHt
Old 08-06-2016, 11:52 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Volt
I threw mine into a cheap wooden box from a craft store.
