Old 06-23-2010, 08:01 PM   #1
t-moss1
Default timing the flathead
can you time a flathead using a vacume gage? by hooking up a gage to the wiper port, then moving the advance, retard plate untill the most vacume is reached?
t-moss1 is offline   Reply With Quote
Old 06-23-2010, 08:25 PM   #2
34flathead
34flathead's Avatar
Default Re: timing the flathead
i am running a warmed '52 flathead and the best timming is at 19 1/2 inch of vacuum, using the timming light to see where the bump on the pully is just for documentation if i ever need a reference point and dont have a vacuum gauge with me.
rich
34flathead is offline   Reply With Quote
Old 06-23-2010, 09:35 PM   #3
flatjack9
flatjack9's Avatar
So what timing did you have at that point?
Old 06-23-2010, 09:49 PM   #4
Henry/Kokomo
Henry/Kokomo's Avatar
To answer your question,"Yes".
Henry/Kokomo is offline   Reply With Quote
Old 06-24-2010, 11:19 PM   #5
34flathead
34flathead's Avatar
i am at 2 degrees btdc or negative 2 degrees, that is assuming ( i know ) that the bump is the actual top dead center.
rich
Old 06-25-2010, 12:42 PM   #6
flatjack9
flatjack9's Avatar
I believe the bump is 2 -3 deg BTDC.
Old 06-25-2010, 07:18 PM   #7
Zurekbrau
Zurekbrau's Avatar
That works the best for me to.
Rich
Illegitimi non carborundum
Zurekbrau is offline   Reply With Quote
Old 06-25-2010, 10:32 PM   #8
34flathead
34flathead's Avatar
i have been told that the bump = 2 degrees, so i am negative 2
that is measuring the width of the bump and calling it 2 degrees, it even ran good at negative 4 degrees 18 1/2 inch vacuum, but not 6, had to find the where it starts going bad, but it is best there, 19 1/2 inch vacuum.
lots of people have told me the bump was not an accurate mark? i have not had some one help me find the exact tdc, but if i can find a 15/16 socket to grind down 1/4 inch so i can turn the crank with a breaker bar, i will degree my pulley.
rich
Old 06-25-2010, 10:38 PM   #9
52merc
52merc's Avatar
im with you the timing mark is 3 deg b4tdc,thats where you work from,,ol ron has done lots of testing of this i think its in his book
52merc is offline   Reply With Quote
