08-13-2018, 05:35 PM | #61 | |
Re: Pulling my hair out over this misfire
Hey, thanks for the heads up! When I take the spring off for the new seals I will give it the “wiggle test”. Sent from my iPhone using Tapatalk |
08-16-2018, 10:05 PM | #62 |
Well, I’m done. I pulled the spring today and cant budge that valve. It had some black rubbery goo kind of like carbon but not hard. I was able to scrape it off with my fingernail. It was on the guide and the stem.
Whatever it is I suspect that’s what’s hanging it up. I put on a positive seal and buttoned things back up. No smoke at all for the first minute. Still running kind of rough at times. Once I took it on the road though it started smoking again. I think the head needs to come off and it needs to be cleaned. I’m tapping out at this time. On a separate note I adjusted the valves on that side and it sounds real nice lol. Thanks again for all your help. I’m sad I can’t fix it myself, but “A man’s got to know his limitations” Sent from my iPhone using Tapatalk |
09-23-2018, 07:22 AM | #63 |
Good news. I got the valve unstuck and she runs again!
The facility that was going to fix the truck had a month and a half before they could even get the truck in. Two days ago I said “screw it” and opened it up again. Sprayed some PB Blaster on the stem and let it sit for a half hour. Gave the valve a few whacks with a hammer and a wooden dowel and it started moving. More PB Blaster. A few more whacks and good to go! I couldn’t believe it. Put her together and she runs. Thought you guys would want to know. Thanks for your help! Sent from my iPhone using Tapatalk |
09-23-2018, 08:01 AM | #64 | |
Actually, what you did is correct and leads to no need for head R&R. I wonder if the black goop you described was what was left of a failed umbrella seal?
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
09-23-2018, 08:03 AM | #65 | |
Most likely. It was a bit rubbery and not hard like carbon. I will plan on replacing them all this winter just to be safe. Sent from my iPhone using Tapatalk |
10-07-2018, 07:18 PM | #66 |
Good job!
Thank God this is only a hobby! |
10-07-2018, 07:50 PM | #67 |
