02-08-2022, 02:48 PM | #1 |
Eraly Ford rear hub bearing included drum and studs removed
City:
Wallingford
State:
CT
Price:
75.00
This is a nice rear hub originally the plan was to put a Buick finned drum on it that's the reason the the original drum has been removed. The Ford drum was mounted on the front of this hub. The original bearing and seal are in the hub. Asking $75.00
Shipping is extra. Please send me message if interested.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 02-12-2022 at 05:30 PM. |
02-13-2022, 08:17 AM | #2 |
Re: Eraly Ford rear hub bearing included drum and studs removed
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
