Old 07-17-2021, 09:57 PM   #1
chrs1961815
chrs1961815's Avatar
Default X Connecting Rod Measurements
I am looking for the measurements of an early x connecting rod. Overall length, width, etc. If you have regular original rod too, could you take a side by side pic? Thanks!
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-18-2021, 04:29 AM   #2
CA Victoria
CA Victoria's Avatar
Default Re: X Connecting Rod Measurements
I can ship one each to you for $8?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 07-18-2021, 08:05 AM   #3
chrs1961815
Thanks but I really just need the measurements. If nobody can provide I might take you up on your offer.
Old 07-18-2021, 09:18 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
It's the same except for the "X" instead of the "H"
Center to center 7.498-7.502
i have a later print (H type) that calls out weight specs small end ,198 +/- 1 gram, large end 512 +/- 1 gram
Old 07-18-2021, 02:08 PM   #5
chrs1961815
Is the dipper the same? Thanks.
