Old 10-15-2020, 07:05 PM   #1
Sckxyss
Default Aftermarket radiator cap.
I buy a radiator some time ago at a swamp meet and the cap is not the standard one. It was made in USA and the threads are 2 1/2 in diameter.
Someone can tell me if a cap is available?
Regards.
Sckxyss is offline   Reply With Quote
Old 10-15-2020, 07:06 PM   #2
Sckxyss
Default Re: Aftermarket radiator cap.
Regards.
Old 10-15-2020, 07:43 PM   #3
McMimmcs
McMimmcs's Avatar
is that a Model A radiator ?
Old 10-15-2020, 08:01 PM   #4
700rpm
700rpm's Avatar
Your cap is the right diameter, but that radiator neck doesn’t appear to be a Model A. A photo of the cap would help to determine if it resembles a Model A cap, and another picture of the neck with the cap as it sits (or doesn’t) in relation to the neck.
Ray Horton, Portland, OR
Old 10-15-2020, 08:04 PM   #5
duffy
That's been modified. Model A caps are not threaded. At least my '31 is not.
duffy is offline   Reply With Quote
Old 10-15-2020, 08:10 PM   #6
700rpm
700rpm's Avatar
28-29 caps are threaded. 30-31 are not.
Old 10-15-2020, 09:41 PM   #7
Bob C
Looks like an aftermarket aluminum radiator.
Old 10-16-2020, 10:19 AM   #8
Sckxyss
Forgot to say, it's an aftermarket radiator i need a 28-29 cap. I have few old radiator who are not threaded. Thanks.
Old 10-17-2020, 12:20 PM   #9
daren007
Sell it at another swap meet.
daren007 is offline   Reply With Quote
Old 10-17-2020, 01:57 PM   #10
McMimmcs
McMimmcs's Avatar
Sometimes a bargain is not a bargain! Think you got taken on this one !
Old 10-18-2020, 10:23 AM   #11
Purdy Swoft
Purdy Swoft's Avatar
Threaded radiator necks are available from some model A parts vendors .. Care must be taken if installing a radiator neck or the radiator shell won't fit .
Old 10-18-2020, 12:19 PM   #12
Gene F
Gene F's Avatar
My radiator is a 28-29, and it is threaded
Gene F is online now   Reply With Quote
Old 10-18-2020, 02:37 PM   #13
Purdy Swoft
The 1930 pick up and AA trucks up to June 1930 used a 28-29 style radiator with the later style tabbed cap .
Old 10-18-2020, 03:17 PM   #14
eagle
eagle's Avatar
I believe the original 28-29 radiator cap threads are 2 3/16 inch. If the cap you have is indeed 2 1/2 inch, it's not correct for an A.
