03-30-2017, 01:43 PM | #1 |
where can i get a straight fuel fitting for my 46-48 fuel pump
hi guys need the correct fitting to run 5/16 hose from the fuel pump to the carb.I dont know what thread the pump has its one from C&G ford with glass bowl. any help would be great..thanks
"I have built my organisation on fear"..Al Capone. |
03-30-2017, 04:07 PM | #2 |
Re: where can i get a straight fuel fitting for my 46-48 fuel pump
Call Ken Isodor. 203-260-9780. He is an old carb guy going out of business and selling off his inventory. He will answer all your questions and should have that fitting.
John |
03-30-2017, 04:13 PM | #3 |
its supposed to be a metal line from pump to carb, with special ford compression fittings. its not pipe thread.
03-30-2017, 05:30 PM | #4 |
I use brake line and a compression ferrel. Looks right and works great
03-30-2017, 05:30 PM | #5 |
My glass bowl pump has 1/8" NPT threads. Maybe there are different kinds. If you are using a hose, google 5/16 x1/8" NPT hose barb for sources.
03-30-2017, 05:32 PM | #6 |
03-30-2017, 06:44 PM | #7 |
OMG!
So many different replies. There is a fitting to go into your pump (straight thread with a gasket) that will accept the copper line to the carb which has compression fittings. Yes, copper line for easy bending to align for attachment. A rubber hose is not original. John |
03-30-2017, 08:00 PM | #8 |
Maybe Charlie NY will chime in here with the REAL facts.
03-30-2017, 08:59 PM | #9 |
hombres,
EDELMANN 842550 is what you need.....NAPA or O'Reillys can get them. Speedway has one that is longer their # 916-11064 Stromberg and 94 style carbs use the same fitting. Any questions get me at [email protected]. Charlie ny Be sure your hose is ethanol proof, don't be using a chunk you found under the bench |
03-31-2017, 06:59 AM | #10 |
The Ford fuel pump with the glass bowl for the fuel filter came in two versions. Early style has straight threads 1/2-20 with a seat for the fuel line ferrell. Later on there was a change to 1/8 NPT thread without a seat.
03-31-2017, 04:56 PM | #11 |
thanks guys,ken got in touch with me and hooked me up with the part.Thanks for all your replys
Thread Tools | |
Display Modes | |
