05-04-2012, 06:38 AM | #81 |
Re: 1935-1941 Ford Pickup Parts
Sent you a pm about some stuff.
07-21-2012, 03:31 PM | #82 | |
I need the following for a 1935 pickup: 1. spare tire mount bracketry 2. metal trim moulding that goes on cab at windshield sides, these are each about a foot long or so. 3. either 3.25 or 3.54 ring and pinion set for stock rear end. must be very good condition, no whiners. |
07-26-2012, 01:27 PM | #83 |
I'm looking for a nice pair of wide fives in the 5" width. PM if you have. Thanks,
Gene |
07-30-2012, 08:34 AM | #84 |
I need a complete glove box door and hinge for 36/36 pickup
Vernon Blackwood 281-923-5000 |
08-18-2012, 05:29 PM | #85 |
Hi, after a 40-41 pickup hood and grill if you could help with either, don't matter about condition...reply to [email protected] thanks
08-24-2012, 12:27 AM | #86 |
Would you have any door hinges I need 2 left hand side and 2 right hand side, if so how much and would you USPS them to Brisbane Australia? many thanks kenny |
08-27-2012, 07:22 PM | #87 |
hi there
how much do you want for full set of 36 pickup hinges? and will you post them to brisbane australia? thanks kenny |
08-28-2012, 05:47 PM | #88 |
do you have a set of 35-36 ford front fenders? any condition. thanks
08-29-2012, 07:03 PM | #89 |
need a 37 pu right inner front fender well
09-15-2012, 11:34 PM | #90 |
hey Aircooled, I need a pair of steel front fenders & also a pair of steel rear fenders & steel running boards for 35-36 Ford pickup. Have any good ones ? If so, how many pair? My email is [email protected] thanks!
09-18-2012, 11:28 AM | #91 |
Hi! The '36 pickup seems to have a small panel between the rear fender-bed-running boards. I assume these are usually lost or damaged on old trucks but if you have some that are really rough they will work great on the "as is" driver. Thanks and way to go, keepin' the pickups rolling! P.S. I'm also interested in a specific flathead block from early pickups to rebuild. Thanks!
09-24-2012, 08:36 PM | #92 |
Any leads on 38-39 one-ton fenders or running boards?
10-04-2012, 10:58 AM | #93 |
looking for 41 pickup frame....
11-09-2012, 09:40 AM | #94 |
How about a 37 windshield frame ?
11-15-2012, 12:31 AM | #95 |
In need of the upper and lower radiator splash pan. Let me know if you have one.
11-15-2012, 12:33 AM | #96 |
In need of the upper and lower radiator splash pan. Let me know if you have one. Forgot to add for a 37 pickup
11-25-2012, 08:13 AM | #97 |
Looking for 35-36 pickup truck column drop complete with key 713-826-2582 Tim
12-01-2012, 06:39 PM | #98 |
I have a rare 41 ford pickup radiator from the n series flat head 4 cylinder if your interested or have people looking for one
Jeff [email protected] |
12-11-2012, 09:17 PM | #99 |
sent you an email about a grille.
12-25-2012, 11:06 AM | #100 |
Need front fenders for 35 pickup. Also grill, any front sheet metal.
