Old 01-19-2021, 03:37 PM   #1
adileo
adileo's Avatar
Default MiG help
Hi guys
Little off early Ford but will use on F1.
I am a newby in welding arena. I bought an old/used Lincoln SP-100 (see pic). While practicing on old piece of sheet metal, I ruined the tip. Probably wire feed to slow or too hot...but getting off my need.
I went to Home Depot and bought new Lincoln tips. Only to find when I got home the thread diameter is smaller than my machine. Anyone know where I can find these old style tips?
I went to local welding shop and they said I needed buy all new hose torch setup.
File Type: jpeg 8B97D427-319A-44A0-8D3E-A0D4ADACDC09.jpeg (33.5 KB, 122 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 01-19-2021, 03:42 PM   #2
Kube
Kube's Avatar
Default Re: MiG help
I'd check ebay, amazon, McMaster-Carr. Do a search with the model number.
There's a ton of stuff available for that model. An entire new gun / hose assembly is cheap. Here's one of many links - this one Amazon.
HITBOX 10 Feet (3m) MIG Welding Gun Torch Stinger 100Amp Replacement for Lincoln Magnum 100L K530-5, MIG Gun and Cable SP-100 100I 100T 125 Plus 130T 135 Plus 135T 140I 170 170T 175Plus 175T
Old 01-19-2021, 03:50 PM   #3
adileo
adileo's Avatar
Thanks Mike, I did try eBay and Amazon. But they looked like the same tips I got from Home Depot. I’ll continue the hunt and also look your hit box suggestion.
Stay well!
Thanks
Andy
1952 F1
Old 01-19-2021, 04:15 PM   #4
Bob C
Can you post a picture of what you have?
Old 01-19-2021, 04:29 PM   #5
cas3
usually at a real welding store they have enough tip variety's to make your head spin. gotta have model numbers when shopping
Old 01-19-2021, 04:37 PM   #6
Kube
Kube's Avatar
Stay well!
If you buy the entire assembly (about $50) , you get tips. Plus the assembly is now of a more modern design should you need more parts in the future.
Old 01-19-2021, 04:51 PM   #7
adileo
adileo's Avatar
Sorry didn’t think I would run into this issue, it went in trash
I found manual online, pic had model number of tip I need. However, also read a post it’s discontinued and replaced with, kb2011-2b1. However not been able find that either.
File Type: jpg B8268EE5-2A17-4C3C-8226-ECA3FBBD8210.jpg (15.9 KB, 13 views)
Thanks
Andy
1952 F1
Old 01-19-2021, 04:52 PM   #8
adileo
adileo's Avatar
Agree Mike, I’m leaning that way.
Thanks
Andy
1952 F1
Old 01-19-2021, 05:07 PM   #9
skidmarks
skidmarks's Avatar
Find your local welding supply. You might be able to change the diffuser to use the current style tips.
If they repair machines, like the place i deal with , they have used parts.
Depending on how old your machine is and if it sat around a long time with wire in it, chances are it needs a liner. A bad liner will cause you more problems then just with tip burn back
Ad that all up you can buy a new gun.
skidmarks is offline   Reply With Quote
Old 01-19-2021, 05:22 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
Hi guys
The SP-100 tips have a thread that is 6mm. x1 dia.
Notice that your machine is set up for gas.
Suspect that it was converted to gas from flux and non Lincoln components were used.
This is the standard SP-100 wand.
Old 01-19-2021, 05:41 PM   #11
Tim Ayers
I has thinking the same thing.
Old 01-20-2021, 08:00 AM   #12
corvette8n
corvette8n's Avatar
Are you using flux core wire?, also get yourself some nozzle gel, helps the spatter not to stick.
Old 01-20-2021, 08:29 AM   #13
34PKUP
34PKUP's Avatar
Looks like a gas conversion to me not flux-core.
File Type: jpg 8B97D427-319A-44A0-8D3E-A0D4ADACDC09.jpg (45.6 KB, 60 views)
34PKUP is offline   Reply With Quote
Old 01-20-2021, 10:22 AM   #14
Fordestes
If you are using a gas conversion you must make sure the polarity is correct, when I switch from GMAW TO FCAW . The polarity for FCAW welding should be set for D.C. negative electrode, A.K.A DECEN and for GMAW ( Mig ) the polarity should be set for direct current electrode positive A.K.A DECEP or reverse polarity, I Use mostly 75/25 gas for general Mig Welding and 90/8/2 in some cases, depending on what I am welding. The wire and gases I Use depends on what material I am welding ,you can expect a good deal of spatter when using flux core. That torch looks like a Tweco I had , I bought some parts from Harbor freight.
Fordestes is offline   Reply With Quote
Old 01-20-2021, 11:10 AM   #15
51 MERC-CT
51 MERC-CT's Avatar
Perhaps a non-technical clarification on switching polarity for gas usage.
Old 01-20-2021, 11:37 AM   #16
Wooden Shoe
I too own an SP100 welder set up with gas, which I’ve owned for 25 years, purchased new. The tips are not threaded into the torch but are off-center. To install they need to be put into the torch and turned one-quarter turn to lock in. My welding supply store indicates these tips are no longer available and I need to buy a new torch with the threaded tips. If anyone knows where to buy the old tips, I’d appreciate knowing where.
Wooden Shoe is offline   Reply With Quote
Old 01-20-2021, 12:07 PM   #17
AnthonyG
AnthonyG's Avatar
SkeevE-bay has new replacement SP100 Torch $44.00 for wire w 10’ connection wires
Nomad
AnthonyG is offline   Reply With Quote
Old 01-20-2021, 01:51 PM   #18
Bruce_MO
I had the same issue with my old SP-100; new tips are not compatible with my 20+ year old torch. Spent an hour at my CeeKay welding supply source in St. Louis and they were totally stumped. Could not find an older part number, and none of the old-timers at that store and the other store they called could find something for me. The newer torches use a screw-in tip, and mine has a 1/4-turn camlock effect. There's no obvious camlock feature, though; it just looks like a smooth round bore in brass and a smooth tip. But it really works after a 1/4 turn. I have one decent tip left, and when I bugger that one, I will probably buy a complete replacement torch
Bruce_MO is offline   Reply With Quote
Old 01-20-2021, 02:52 PM   #19
adileo
adileo's Avatar
Thank guys. I just bought new torch.
Thanks
Andy
1952 F1
Old 01-20-2021, 02:55 PM   #20
skidmarks
skidmarks's Avatar
Bernard guns use a 1/4 turn tip. But i dont know if they make a gun that small.
In the past i also noticed that the lincoln machines sold at home depot were not the same as the commercial models.
