Old 09-20-2020, 05:24 PM   #1
Krylon32
Default Roadster Dash Screws
What threads are the screws that hold the dash to the body in a 32 Ford Roadster?
Krylon32 is offline   Reply With Quote
Old 09-20-2020, 06:23 PM   #2
glennpm
glennpm's Avatar
Default Re: Roadster Dash Screws
12-24 I believe. David will be along shortly ��
Old 09-20-2020, 07:41 PM   #3
35fordtn
35fordtn's Avatar
They are a 12-24 binding head screw 5/8” long.
Old 09-20-2020, 09:09 PM   #4
DavidG
DavidG's Avatar
Yep, nickel plated.
Old 09-21-2020, 05:27 AM   #5
PeteVS
PeteVS's Avatar
If you have a screw in hand, and want to be able to know its nominal "number" size, there's a formula for that. The nominal size is the "number" of the size multiplied by .013 and then added to .060. That nominal size is actually the maximum size of a tap so the screw would be a couple of thousandths less. In this case, a #12 screw would be (12 x .013) + .060 = .216. So if you put a micrometer or a pair of calipers on the screw, you should expect them to read about .212 to .215 or so. A #6 screw would be (6 x .013) +.060 = .138 or so.
