11-05-2019, 11:22 AM | #1 |
12 volt starter solenoid
Anyone have a current part number for a 1950 Ford starter solenoid but 12 volt version ? Has two large post and one small post for the push button.
11-05-2019, 01:08 PM | #2 |
Re: 12 volt starter solenoid
Ken, I used this on my 40 Ford 12V conversion. Has lasted 12 years so far.
I painted top metal part black. I used it in conjunction with a 12V hidden ignition switch, not the OEM Ford push button set up. https://www.ebay.com/itm/12V-Starter...UAAOSw9yldFOc3 Last edited by 19Fordy; 11-05-2019 at 02:18 PM. |
11-05-2019, 01:20 PM | #3 | |
Hey Ken....Apparently the 3-terminal solenoids that LOOK like the old black Ford solenoids are becoming hard to find. All I could find in 3-pole that had a GOOD review was this COLE HERSEE 24106, this one at Amazon. DD |
11-05-2019, 01:23 PM | #4 |
I think V8 got it right.
Forget my post. |
11-05-2019, 07:56 PM | #5 |
Good to know that Cole Hersee makes that solenoid, They have their name on it which is a good sign. They used to mfg everything in South Boston MA, now it's Mexico. Can't beat their HD battery switch.
11-06-2019, 09:53 AM | #6 |
11-06-2019, 10:29 AM | #7 |
6 or 12 v doesn't really matter to the solenoid. its amp rated
11-06-2019, 11:11 AM | #8 |
Voltage CAN matter to the coil. I've run across 12v solenoids on which 6v will NOT energize the coil. DD |
11-06-2019, 11:44 AM | #9 |
Since the O/P is going the other way, it should work. I have a 6 volt solenoid on my engine test stand that can use either voltage and it has performed flawlessly for several years under both voltages.
