12-18-2018, 05:48 PM | #1 |
Strombergs 97 Thread size
What's the thread size inside the fuel inlet hole in the Stromberg 97 body? Got one that the threads are stripped.
12-18-2018, 05:54 PM | #2 |
Re: Strombergs 97 Thread size
Common deal. Some of the rebuilders sell threaded inserts. I used to make them for my carbs. I think I used 9/16 nf bolts so half the work was done. I drilled and tapped them to whatever the threads were stock. I put the inserts in deep so the gasket still sealed on the housing and not the insert. I did not tap the housing all the way thru so the insert would bind up on the unfinished threads. They always worked pefectly.
12-18-2018, 06:08 PM | #3 |
To answer your question, those threads are 7/16-24.
I have inserts.
12-18-2018, 07:20 PM | #4 |
Thanks !
12-18-2018, 08:44 PM | #5 |
{Jamie is a mate of mine}
