01-11-2011, 09:55 AM | #1 |
94 carb question
There is a hole in the top cover into the fuel bowl located by the choke
lever,not all 94's have this hole, what is it's purpose?..........Bob |
01-11-2011, 10:00 AM | #2 |
Re: 94 carb question
In the hump above the pump, backside??
This is one of several venting types used over the years. Others involve the oval depression near front center opened into a hole and a vent tube into the throat used after the war. I think the rear facing one you have correlates with about 1942, for early cars with high mounted fan. |
01-11-2011, 12:21 PM | #3 |
01-11-2011, 12:31 PM | #4 |
Both are right,need to know better the location of the hole. ken ct.The heater hole can be plugged up with a piece of solder hammered into the holefrom both sides and file smooth on the outside,its almost invisible after you glass bead thetop. Ive plugged a hundred of them like this.ken ct.
01-11-2011, 07:26 PM | #5 |
