09-11-2017, 05:56 PM | #1 |
engine backfire when slowing down
I have a 56 with 292 engine 4 barrel tea pot carb. the carb was rebuilt last year. I am getting some backfiring thru the exhaust when engine braking.
The car has glasspack mufflers. Could this be caused by a to rich fuel mixture or possibly timing problem. Engine runs smooth and accelerates well. It also is hard to start after it sits for a couple days(takes a lot of pumping of the gas pedal) |
09-11-2017, 06:47 PM | #2 |
Re: engine backfire when slowing down
All true gearheads love that backfire sound! Roll the window down and enjoy! (Or am I giving away my age here?!)
This is caused by the presence of both unburned fuel and oxygen in the hot exhaust manifold. The heat or flame from a cylinder's open exhaust valve ignites this unburned fuel-bam! Under the right conditions, she'll really cackle! If you really want to quiet it down, check that the timing is OK (if you have the original Load-O-Matic vacuum only advance, make sure it is working). Maybe richen the idle mixture a little. May be comparing apples and oranges here, but with my Model A in high school, if I wanted it to backfire more, I would close the mixture rod (GAV) to lean it out and throw the spark lever up to full retard. Result: lots of noise (blown muffler). If I left the timing advanced and kept the mixture knob open, it was much quieter on deceleration. Finally, add a dashpot to the carb. This slows down the closing of the throttle plates instead of them snapping shut when you back off. They were standard on auto trans cars back then. For the hard starting, the float bowl may be leaking into the intake. Does it act flooded after sitting a couple of hours? Try looking down the secondaries with the throttle held open. You will get a couple drips from the accelerator pump, but if you see puddles, the carb has issues. |
09-11-2017, 07:19 PM | #3 | |
If the carb is draining the gas out and down into the engine, and leaving the carb dry, you possibly have a leaking power valve. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
09-11-2017, 10:05 PM | #4 |
Also sometimes if fuel is dripping in the venturi after engine is turned off when warm you may see a smokey white vapor coming out of the carb. Also if you have an exhaust leak near the exhaust manifold it may cause exhaust backfire.
09-12-2017, 09:10 AM | #5 |
I am with 40 DELUXE, sit back and enjoy the sound, every car I had after putting on glass packs will pop back, my 56 to slow down I will pull down to low and she will really crackle. also we use to block off the heat risers with pennies on the flat heads to get them to pop back.
09-12-2017, 10:49 AM | #6 | |
. Last edited by dmsfrr; 09-12-2017 at 02:22 PM. |
09-12-2017, 10:50 AM | #7 |
A bit of popping when decelerating is normal and sounds great. The closed throttle plates and higher vacuum cause the mixture to go rich. Double check the color of the spark plugs or the color of any soot buildup at the ends of the tail pipes.
If it's too dark the normal running mixture could need to be leaned out a bit. . Last edited by dmsfrr; 09-12-2017 at 02:38 PM. |
09-12-2017, 12:22 PM | #8 |
It's virtually impossible for a leaking power valve or economizer diaphragm to drain the bowl on a Holley 4000, 2140, 885F or ant teapot style Holley carb, 2 or 4 barrel.
Completely different design than the other Holley power systems. (like the Holley 94 type carbs). Sal |
09-21-2017, 03:47 PM | #9 |
Modern fuel today will evaporate sooner than the old stuff. To solve the hard start after a few days, install an electric fuel pump under the back seat, (on the outside of the floor pan), and use a toggle switch to activate for 30 to 45 seconds before you try to start it. The engine pump will pull through it for normal driving.
09-24-2017, 09:47 PM | #10 |
I'd check the points. Modern points are junk and the rubbing block goes away pretty fast until it gets seated. When the points start loosing their gap, you will get pop on deceleration.
09-25-2017, 03:31 PM | #11 |
02-04-2018, 09:56 AM | #12 | ||||
WHISTING THROUGH THE GRAVEYARD
EXCEPT!... Using only manifold vacuum for the vacuum advance feature is not the way to go IMO. The 1956 Y had a dual diaphragm vacuum advance canister and the rearmost chamber is attached to full manifold vacuum. This feature allows full vacuum advance (over-riding the LOM signal) @ engine deceleration by burning the mixture with closed throttle plates more completely eliminating the delayed IGN in the exhaust system. Most likely either the canister is defective and/or the manifold vacuum signal is not reaching the canister. !!! EDIT !!! - CORRECTION! - GIG! Quote:
The FRONT CHAMBER is connected to full manifold vacuum, the REAR CHAMBER is the LOM feature signal. ...sheesh...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 02-04-2018 at 04:55 PM. Reason: THE USUAL - TERMINAL CRS |
02-04-2018, 12:55 PM | #13 | ||
https://www.ctci.org/gilsgarage/Crac...stManifold.php The vacuum diaphragms can be checked fairly simply with a 4 to 6 ft piece of flexible vacuum line. The '54/'55, '56 and '57 distributors use a different style vacuum canister each year, and are vacuum pressure matched to a carb from that year. It's my understanding the '57 and newer carbs & distributors use a common/interchangeable vac pressure standard. https://www.ctci.org/gilsgarage/Vacu...Mechanisms.php Quote:
Hopefully it's compatible if the points rubbing block is made from different types of plastic. I've seen some that look like a darker phenolic/bakelite and others are a lighter almost white plastic. Last edited by dmsfrr; 02-28-2018 at 12:30 PM. |
02-04-2018, 04:37 PM | #14 | |
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
02-05-2018, 04:12 AM | #15 |
OH! BTW-
FORD (MOTORCRAFT) points and condenser are still available from parts vendors and/or found on E-bay- 1954-56 Y-BLOCK- Points FAB 12171-B - Condenser FAA 12300-A 1957/ Points B8Q 12171-A Condenser B7A 12300-C The B7A Condenser seems to be hard to find NOS and to be mainly aftermarket (CHI-COM). With all of the specialty shops still out there, there has to be those that specialize in LOM distributor rebuild and/or re-curve.
02-05-2018, 06:05 PM | #16 | |
I found a one-man shop in Denver to get my ('57) dist rebuilt, he was listed in the Hemming's classifieds. I suspect that due to low volume and the age of any remaining rubber NOS parts, replacement vacuum canisters for these cars will become more expensive, and with limited sources. . Last edited by dmsfrr; 02-05-2018 at 08:28 PM. |
02-05-2018, 08:10 PM | #17 | |
02-06-2018, 06:36 AM | #18 | |
Where are they located and I guess they do work with shipping? I was thinking of a shop that has a SUN MACHINE with the ability to simulate/provide the LOM vacuum signal(s) to properly curve a LOM dist.
02-06-2018, 10:14 AM | #19 |
If it is an actual backfire and not the popping described by others, it could be a leak in the exhaust drawing cold air into the exhaust. I had that happen on my 56. I fixed the leak and stopped the occasional backfiring.
Matt 24:36-41 |
02-06-2018, 10:57 AM | #20 |
They are somewhere in southwestern Florida per the area code. No website. One of my cohorts gave me a flyer they were handing out at a car show. He has had them recurve some FE distributors and is happy. I called the tech info/shop number last night to confirm they're still in bidniz; they do answer the phone.
