09-24-2019, 10:26 PM | #41 | |
Re: timing advance how much is to much
Flatheads might be around longer. All that electronic and plastic has time limit less then metal. But I could enjoy 800hp and not complain! |
09-25-2019, 07:21 AM | #42 |
While electronic engine management systems are superior they're more complicated with many parts prone to intermittent failure making them a pain to diagnose. With a flathead you can pretty much see what is or is not working. Even when it is not you can still make it home many times.
Back to the chevy distributor. As Charlies NY explained to me once, it is all about the ping. You can run a few more degrees total advance and when you open the throttle the vacuum drops out giving you enough retard to avoid pinging.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-25-2019, 09:55 AM | #43 |
To a Hotrodder, nothing is ever perfect?
09-25-2019, 10:07 AM | #44 |
09-29-2019, 03:34 AM | #45 |
parts arrived on Friday so Saturday spent reworking dissy reinstalled at 4 deg with 18 deg at 3500 just back from a 450 klm day run today ran like a swiss clock never mjssed a beat THANKS TO ALL for their help comments and thoughts
09-29-2019, 12:12 PM | #46 |
09-29-2019, 01:55 PM | #47 | |
Only Charlie has the correct info? Wow the guys original question for this post is Timing Advance and how much is to much.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
09-29-2019, 02:02 PM | #48 |
Not only is the total advance a little low in degrees, it is coming in late isn't it? You would want total in around 2000-2400 rpms.
09-30-2019, 10:08 AM | #49 |
yes and done by educated guess work and checked with only a tacho and a advance check timing light not a bad effort considering the parts sent where for a different dissy not a yh series but its better than what some YOYO in the usa bolted together as i said before looks cool pity it runs like shit yes ron not the perfect curve achived but better and all advice was taken into consideration AGAIN thanks to all who took the time to reply
09-30-2019, 03:23 PM | #50 | |
Interested to know how the vacuum is looking now at this set up. Improved? Phil NZ |
09-30-2019, 05:06 PM | #51 |
yes Phil much improved now have 18" at idle 550rpm again no off idle stumble and it just drives much happier will try again when i can locate a set of YH keys and springs as mallory/msd say they are nil stock and only appear to carry the latest spares watch their freight $18 dollars us turned into $65 aus by the time it got here
Thread Tools | |
Display Modes | |
