11-13-2020, 01:47 AM | #461 |
Re: photo1-1-window
T5 S-10
11-14-2020, 02:46 PM | #462 |
Re: photo1-1-window
COIL VOLTAGE/OHMAGE:
____________________________________________ _______________________________________________ __________________________________________________ What is often called a 6v coil will work fine on 12v, positive or negative ground. As you posted, it is the current in the circuit that needs to be controlled in the 3 to 4 amp range. With a "6v" (really one in the 1.5 ohm range) you need a ballast resistor (also in the 1.5 ohm range) for use with 12v. So, you are looking for ~3.0 ohms of resistance for a 12v ignition circuit. Or, you can use what is referred to as a 12v coil, really a 3.0 ohm resistance coil, as it provides the 3.0 ohms of resistance without a ballast resistor. The polarity of the coil needs to match the polarity of the rest of the system, so a negative ground system has the negative terminal of the coil going to the distributor points & capacitor and the positive terminal of the coil connected to the ignition switch. |
11-15-2020, 02:03 PM | #463 |
Re: photo1-1-window
Test |
11-18-2020, 12:33 PM | #464 |
Re: photo1-1-window
RHD (RIGHT HAND DRIVE) AUSSIE |
12-02-2020, 01:26 AM | #465 |
Re: photo1-1-window
Cell #: 716-440-8952
12-03-2020, 11:54 AM | #466 |
Re: photo1-1-window
12-05-2020, 02:16 PM | #467 |
Re: photo1-1-window
Solenoid
12-06-2020, 01:32 AM | #468 |
Re: photo1-1-window
BROKEN BELL
12-06-2020, 01:35 AM | #469 |
Re: photo1-1-window
'40 TRANS
12-13-2020, 03:48 AM | #470 |
Re: photo1-1-window
Lights
12-17-2020, 01:55 PM | #471 |
Re: photo1-1-window
4-CYL BELLHSNG |
12-22-2020, 03:55 PM | #472 |
Re: photo1-1-window
GRUB SCREW
12-23-2020, 03:58 AM | #473 |
Re: photo1-1-window
One thing you learn from history....is that nobody learns from history! |
12-23-2020, 04:47 PM | #474 |
Re: photo1-1-window
BANJO DRAIN HOLE
12-23-2020, 05:06 PM | #475 |
Re: photo1-1-window
TRUCK OPEN BANJO
12-29-2020, 01:37 PM | #476 |
Re: photo1-1-window
'32-'34 Banjo
12-29-2020, 01:39 PM | #477 |
Re: photo1-1-window
SHOCK Mounts
12-31-2020, 02:28 PM | #478 |
Re: photo1-1-window
Pan
01-01-2021, 06:22 AM | #479 |
Re: photo1-1-window
01-02-2021, 02:49 AM | #480 |
Re: photo1-1-window
49-50 Merc Pics |
