Old 11-19-2020, 05:53 PM   #1
samsonized
Default flathead engine stand
i have a 35 flathead i need to put in an engine stand. will it bolt up to the modern style universal engine stand with the four attaching points
samsonized is offline   Reply With Quote
Old 11-19-2020, 05:56 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: flathead engine stand
If it is a UNIVERSAL engine stand I don't see why it wouldn't.
Old 11-19-2020, 06:10 PM   #3
Cobra Joe
Cobra Joe's Avatar
I was always told you should never hang a flathead by bellhousing bolts as the casting is not strong enough and you should only hang it from the exhaust ports.
1957 Fairlane 500
1939 Ford Coupe
Cobra Joe is offline   Reply With Quote
Old 11-19-2020, 06:15 PM   #4
samsonized
is that an adapter you can buy?
Old 11-19-2020, 06:45 PM   #5
KiWinUS
KiWinUS's Avatar
Yes Stumpys Fab Works.
Old 11-19-2020, 07:10 PM   #6
KiWinUS
KiWinUS's Avatar
Oops let’s not forget HAMB member Havlers house of fab. He makes them also in Va.
Old 11-19-2020, 07:32 PM   #7
hop up
hop up's Avatar
Mike I may have a extra one but will have to see if I still have it . You need to get the KR Wilson flathead engine lift too to make things easier
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 11-19-2020, 07:34 PM   #8
hop up
hop up's Avatar
A better pic with the part number
Old 11-19-2020, 08:45 PM   #9
Hitman
Do you have an extra one of those? I’ve been looking for the KRW version.
Hitman is online now   Reply With Quote
Old 11-20-2020, 11:15 AM   #10
corvette8n
corvette8n's Avatar
Got both of these at Stumpys.
File Type: jpg 48C5EE89-0B09-484F-BFF6-DAA229D0F58F.jpg (50.3 KB, 161 views)
Old 11-20-2020, 12:09 PM   #11
19Fordy
19Fordy's Avatar
Do NOT bolt a pre 1949 Ford V-8 engine to an engine stand buy the cast bellhousing.
Not safe. May break the cast iron. 1949-53 there is no problem.
Old 11-20-2020, 12:11 PM   #12
Tim Ayers
If anyone has a KR Wilson engine lifter like this that they want to sell, please PM.
Old 11-20-2020, 01:24 PM   #13
KiWinUS
KiWinUS's Avatar
^^^^^^^^ I want one also.
Y
Cheers
Tony
Old 11-29-2020, 10:39 PM   #14
Strick
Strick's Avatar
been standing in line for one myself for awhile.....
1940 Mercury
Looking for DENVER heads - 81AS - 99AS - 19AS
Strick is offline   Reply With Quote
Old 11-29-2020, 11:14 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
This gruesome picture is the result of what Jim (19Fordy) is talking about. Some folks get away with it, but like Dirty Harry said....."Do ya feel lucky? Well, DO YA, PUNK?" DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-30-2020, 01:54 AM   #16
Pete
Pete's Avatar
Sorry, I don't buy it on that one. The cracked area is RUSTY for at least 8 inches on the right.
This subject is just like seat belts though, I wouldn't recommend any particular method for hanging a block or attaching belts.
Old 11-30-2020, 06:28 AM   #17
V8COOPMAN
V8COOPMAN's Avatar
That's OK! Here's another "fake" one you can piss about! DD
T5 W/TORQUE TUBE
Old 11-30-2020, 07:51 AM   #18
Mart
Mart's Avatar
The One above belongs to Neil "Biggles" Bennet. It's built to very high spec. I know Neil. He was able to repair it. Re the red one, who's to say it happened recently? It probably happened a while ago and the block was dumped in a corner. It could have had plenty of time to rust. I always use a side mount. Mart.
Old 11-30-2020, 09:02 AM   #19
51 MERC-CT
51 MERC-CT's Avatar
Interesting on how thin the casting looks.
Have the tool to check but no block to check.
Old 11-30-2020, 09:22 AM   #20
JSeery
JSeery's Avatar
It is thin, I current have a block that had the bell housing area busted sometime in the past and repaired. Whoever did the repair did a good job! But the broken area is much smaller than the photos posted. A look at the thickness in the bell area should convince you it might not be a good idea to hang a lot of weight off of it. In addition to the thin material, the bell move the center of gravity of the block out several inches from the mounting point.
Like a lot of things, folks have been doing it for years and getting away with it, in fact I would guess breaking one is fairly rare. But, even a small chance of a catastrophe would keep me from taking the chance.
It is fairly easy to fabricate a mount, I made one using a flat plate to bolt to the existing plate on the stand. Welded a piece on angle to it and the a smaller plate the correct shape to match the exhaust bolt pattern. You can use an exhaust manifold for the hole pattern.
